Why does my truck still blow black smoke?
Sorry, I posted this a few days ago in the wrong forum, and got no answers.
6.0. 115,000 miles. Everything stock, except bully dog intake filter.
I replaced the FICM recently, with one that I bought from the guy who makes those cool You Tube videos, Diesel Tech Ron. I also replaced the EGR valve. I also replaced the intercooler boots on the hot side. I cleaned the intercooler pipes. I cleaned the intake filter as well. I'm still blowing out black smoke, if I floor it when I need to pass someone.
Follow up question: I bought those boots from Riff Raff Diesel and I bought new clamps, too. I'm not sure if I installed correctly. It's already blown one off (it blew the top of the intercooler pipe off, by the turbo, but the boot stays on the turbo) and I put it back on and tightened it all the way down, and I've had to re-adjust 2 times, now, since it acts like it still wants to slip off. Do I simply have the other ones mis-aligned???
are you running a tune other than stock? My truck gets pretty smoky on performance tunes and still lets out a little black smoke on my stock tune and my economy tune.
I just installed the riffraff boots on my truck a few days ago and reused the stock clamps. Did you clean the boots and pipes before installing? I used de-greaser on a shop towel to clean mine and haven't had any issues yet, even at 28psi of boost.
Not that I know of. Honestly, I don't even know what that term really means, so I guess the answer is no.
Diesel Tech Ron says he programs the FICMS so they help your truck run better, but I don't think that's what you're talking about.
How much black smoke are we talking here? a little puff on hard acceration, or enough to **** people off? A lot of excessive smoke could indicate an injector is over-fueling.
I'll bet your turbo vanes are sticking. You're right at the mileage that they start to stick. Do you have the torque app or a scanguage? Monitor VGT and see if it ranges from 85 at idle to 15 at WOT. If it hovers in the 45-60 range all of the time, the turbo is stuck.
So, supposing they are stuck, can I fix it, or do I have to get a new turbo? Tnx.
There are some good videos on YouTube that walk you thru the process.
https://www.ford-trucks.com/forums/1...ot-idle-2.html
I think this is actually the other way around. Your VGT should stay around 40-65% most of the time. If it's at 85% at idle that means it is likely sticking. I could be wrong but that's what I was just reading.
After rebuilding the turbo, cleaning the vanes and polishing the journal where the unison ring rides, the VGT range is now 15 at WOT, high rpm and 85 at idle. This is the result every time, every day. It proves that this is the actual proper operation of the VGT.
I read through that thread you posted and it seems most who are claiming that their range is between 45-65 have P0299 problems in other posts, or have asked questions about how to clean their turbo vanes.
