97 7.3 won't start
06-02-2015, 07:25 PM
on
97 7.3 won't start
just bought a 97 f350 7.3. drove it home washed it. drove down the road and back. Next day wont start. New batteries, starter, cam sensor, mechanical fuel pump, 3/4 tank of diesel, repaired wires to ipr, glow plugs cycle, black smoke out exhaust when cranking. any ideas? no codes
06-02-2015, 07:30 PM
on
does your glowplug light stay on? sounds like you might have a pcm problem.
06-02-2015, 07:37 PM
on
light stays on for 3-4 sec
06-02-2015, 08:34 PM
Does you alt gauge stay way down for two minutes indicating the glow plugs are working and drawing juice?
06-02-2015, 08:37 PM
on
It stays between 8-9 while cranking
06-02-2015, 08:39 PM
You may have to low of voltage to start. The motor needs 10 volts. Put a trickle charger on it for the night.
06-02-2015, 08:43 PM
on
My battery load tester shows 10 v while cranking. I put the newer starter on that turns eng faster.
06-02-2015, 08:53 PM
10v is to low. PCM requires a min of 10.5
A good starting system should hold 11.5-12v
06-02-2015, 09:02 PM
on
I'll check it again tomorrow
06-02-2015, 09:39 PM
For a 7.3 to start you need a min of 500psi HPO, 100 rpm, 10.5v and 20psi of fuel
06-02-2015, 09:44 PM
on
Got 20 psi fuel. 200-300rpm s
06-03-2015, 11:54 AM
Sounds like you need batteries to me.
06-03-2015, 05:02 PM
on
Quote:
Originally Posted by
gwheel12
20 psi fuel, 11.5 v, 200-300rpms, 3000 hpop. where to next?
06-03-2015, 05:21 PM
Where did you get the cam sensor from.
06-03-2015, 06:59 PM
on
Gray sensor from auto zone.
