Ok those are the ones I got so no washers? I bottomed them out by hand and the shallowest hole still gave me a half inch with out the washer and I did the math my washers are only 1/32 smaller than spec
So you've got a half an inch of play room without the washers? If that's the case then go for it. Use the washers you've got.
Yes the space between head of bolt and block is 4" bottomed out and the head itself is 4 1/2" at the same hole and some of the others the block to bolt head is 2 1/2" with 4" on the head those are the exhaust side the shallow hole is the front one on out side of the valve cover
