Free thread monthly pruning
#33
In addition to being cheaper to ship without your ring gear, you will probably be wanting it unless you are doing a gear swap yourself. You aren't supposed to mix and match ring and pinions because they are a matched set lapped together at the factory. Just thought I'd throw that out there, since no one else had mentioned it, in case you weren't aware. Don't want somebody coming up with a rear end rebuild expense they weren't prepared for...
#34
Your aggument is null and void in this conversation about 10.25/10.5 rear axles. You must have never worked on anything in the last 30 years.
#35
on
#37
Ok, so we where taking about a 10.25/10.5 carrier..... This is how it went not?
Than it continued.
I'm not sure where you where going with this, unless you where changing the subject from the 10.25/10.5 rear ends that every vehicle in this section uses to rear ends in general. Either way, idk why I'm even bothering responding.
#41
on
Than it continued.
Than it continued.
#42
Technical Help
This guy LITERALLY wrote the book on rear ends, so I have to believe at least most of what he says...
All of my research and every trans and gear mechanic I have talked to, says that they are. However, knowing mass production, say you are right and Ford doesn't manufacture their ring and pinions like every other company who does lap them. The fact that they have been driven would have worn, or "lapped," them together. I have heard of guys mixing and not having problems, but it was always almost new gears. I know after rebuilding a rear end twice in a month because the guy I was doing it for wanted to try and cheap out and use a used ring gear from a junk yard (right rear end, right number of teeth, double checked), I will never do it again.
#43
on
With all due respect, as I have seen much of your advice that was great and right on, I think I personally have to differ here. However, it's not my rear end or my money, so in the end I don't care which ring gear he uses. Just seems to make more sense to use his own.
Technical Help
Technical Help
#44
Free Parts thread. Emphasis on the "Free" and the "Parts" so keep the yammering OT to a minimum please. This thread isn't like other threads that will typically drift, so please keep it more on-topic and less off.
Thanks.
Stewart
Thanks.
Stewart
