Manual to Automatic
66FordGuy Welcome to and the Slicks Forum.
Best to buy the donor and swap several things at once. You will need the column shift for the gears, the connect point is 2 1/3 in closer to the firewall than your current so you might as well use the power steering also. Since you have spent the money on the donor you might as well swap the I-beams for the power disc brakes too.
It's all bolt hole swap, might take a couple weekends to complete the project but you would be happy that you did.
John
John
Thank you for the information, my dad used to strip trucks back in the day and he kept the transmission and the steering column for the swap and that's all he has now, but I was wondering if the flywheel would work because the 302 is externally balanced and the 240 is internally balanced.?
onehandedbandit
04-26-2011 09:03 PM
Econoline 150
11-21-2008 07:07 PM
davesbronco
04-02-2006 09:32 AM
