whinning noise while in reverse
Start simple
Have you checked the transfluid level?? this would apply to either automatic or standard transmission, not sure what you have but the odds are its a automatic.
If a automatic, & if it is shifting fine then a transmission drain and and replace the filter certainly couldn't hurt. I'd be a little weary of those flush machines, they do exchange the fluid better but some run some pretty high pressures doing it and that tends to create more problems down the road.
as for cost cant help you there, you're best bet is call around and ask in your local area
Itr.#1446
18
12-28-2011 12:38 AM
