Need new suspension, New OEM springs, re-arch old, or Airbags all around?
I need new springs all the way around on my 96 7.3 4x4 F250. I was looking at all my leafs and theyre all about 1 1/2-2"s off the bump stops. If Im going to have to put new leafs on anyway, Im thinking it just makes more sense to buy air bags all the way around and have an infinite adjust suspension so that its super soft and comfy. Can I go air bags as my suspension adjustment on warn out springs or should I get new springs, and better shocks? Or should I just get my old springs re-arched? Anybody every run airbags all the way around on an 7.3 F250 with a TTB D50?
Feel free to send me a message! I can definitely set you up with something that will fit your needs.
-Junior
-Junior
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
www.ATSsprings.com
Thanks man, Ill give ya a shout when the giant void that this truck, the performance tranny, chip, intake, exhaust, fluid changes, interior, and gauges left in my wallet fills back in. 9k went so fast. haha.
I spent a lot of time looking for front springs, to no avail. I had them re-arched at a good truck spring shop. I replaced all of the bushings too. I did not go poly although I should have. I bought the bushings from summitt @ $12 each. The spring job cost me $400.
Junior is the man when it comes to springs!
I did the D50 pivot bushings at the same time and the visible TTB axle camber went away too. Not sure if that was due to the pivot bushings, the shackle bushings or a combination of both of them.
Bob
1.5" isn't very far off stock. Ford designed the IFS springs to be reverse arched. I replaced the fronts on my 94 F250 with a new 3500 lbs HD set from Bronco Graveyard and I ended up with 1.75 inches space at the bump stops.
If you are over 200k miles I'd check and or replace all the bushings 1st. Pivot, spring and shackle. Then see where you sit. If your closer to 1.75, new springs may not be needed.
My 97 was at this point and I opted to do a stock D60 swap instead. There wasn't a huge difference in cost and ride improvement was worth every penny.
Good luck,
Bob
Good luck,
Bob
Good luck,
Bob
Good luck,
Bob
Bob
I seriously considered the D60 swap. What finally stopped me was some information that I got that the D60 has even a wider turning radius than a D50. That "info" came from the internet and may not be correct. My extended cab long bed already has the turning radius of a locomotive and I don't want to make it any wider.
Bob
Bob
EDIT:
I used/replaced all of the linkage, including the pitman arm from the F350. That may explain some of the difference in results.
