Ford Releases TSB 15-0088 For 2015 Active Regeneration Jackhammer Valves Issue
#91
I didn't know about this forum until a member of PSA directed me to this thread. He read my thread about weird vibrations occuring around a regen. You can look me up on other forums, as I use the same name and I have more than 20 posts on other forums.
So if you're inferring that I'm some lifeless user who creates multiple fake accounts on forums to try to make a point to other internet people, you're mistaken.
Nope...not you...someone else.
#92
I heard from Ford today on my case.
I was told that there will be a 'callibration change' released in early 2nd quarter 2016 (9 to 10 months) to address the Active Regeneration Valve issue where the engine shakes anywhere from moderate to a violent level around 30 seconds into regeneration.
I was not told what actually is causing the issue nor why it will take 9+ months.
Will this fix it or are we being slow rolled out of lemon law parameters?
#93
I am inclined to think your theory of delayed engines in early 2014 has some merit. And I'm not even close to a conspiracy guy.
Did you look at the passenger side valve cover/intake yet for a build date?
#94
#96
Thanks Louisanna, no,,, well it can. Some can get out of it by down shifting . There was a guy down in Texas and now under a gag agreement, that couldn't and a few exhaust valve on the driver's bank of course, dropped and the powder metal rods were not having it so they escaped thru the side of block. That story can be found by googling, " 6.7 Blown Motor $25k". It's is or was, it was still to be found on another forum.
I have seen quite a few of motors small hard items got into the cylinder and beat the piston face pretty good and they were ok after removal but it obviously dependent on how long it goes on. In the case of the 6.7 because it's not a seizure of the valve but a monetary stick till the Pistons smacks it out of this state the piston is not be "shredded" due to the lack of major resistance and the geometry used on the valvesbut those who continue to allow the condition, what does happen is spider web cracking radiating out from the guide in the aluminum head.This will eventually lead to a valve drop with spectacular results.
Ford was close with cleaning or replacing them. They would stay out for awhile that way for awhile till the normal film built back up on the stem. This film is normal overtime and is not coking in the traditional sense. Anytime exhaust back pressure exceeds atmosphere the exhaust gasses will escape vent right up the exhaust guide,this is normal. This film takes up the room that was allowing for thermal expansion, now we are sticking again. Minor differences in I.D. On guides from different runs and tooling.
REAM
REAM
#97
#98
I would have a tough time letting anyone tear into a new engine in a 70K truck. And if it didn't fix the problem I would lose my mind.
Maybe Ford (wink wink nudge nudge) would let the affected owners delete the crap that is causing the problem? So there are a few trucks running around deleted. But the problem is solved and the owners are happy.
#99
#100
I did some checking on this issue.
The current theory is that there may be an actual issue concerning the valves. However, it's not what has been described in this thread by some folks.
The issue is that the valves are possibly not seating all the way at slight throttle tip in during regen. The valves are not actually hitting the pistons, so no engine damage is occurring. But because they aren't completely seated, the engine makes noise and some vibration occurs.
Ford is investigating and it will take time to pinpoint, test, and approve an exact solution. It could entail parts swapping, or it could be a calibration update.
That is the information I have received that has trickled down from the powers that be.
The conspiracy theories that Ford is trying to hide this, or that there was a mishap on engine builds, or that customers are being swept under the rug.... all have no merit behind them. This is not a very common problem, and it's difficult for dealers to duplicate. But Ford is now getting more information and is investigating.
#101
#102
#103
#104
That said, its a very small number of trucks. But I don't want to be in that group and I hope the problems get fixed soon.
#105
