Restoring a 73 f100 with original engine, transmission.
1973 f100 dentside. I want to level it out.
Looks for suggestions to level out the front of the truck reduce some of the 40 year old body roll.
I know autofab has stuff. but I was wondering if there was something else I could do. I dont really want to lift it. 31" tires are fine for me. It has 302 to in it. I am wondering if its a mexican block. Its also two wheel drive.
I will change out the bushings and maybe upgrade the sway bar. But do I need one for the back as well?
New shocks, bushings, and a front swaybar will definitely improve handling. Use the OEM swaybar from a 75-79 Dent which mounts in front of the wheels instead of between the radius arms.
Add a rear swaybar later if needed. .. trucks are notoriously nose heavy and understeer at first steering input..
IIRC, 31s can fit with no lift.
It's a bolt-in affair except for drilling the frame for four holes. Here's the setup of a 75-79 swaybar less the C-brackets which are kind of a pain to obtain because much of the donor's front end has to be disassembled. The C-brackets can also be obtained from an Econoline. Also, note that the brackets have an indexing pin which fits into a notch on the leading edge of the radius arms. The notch can be ground into your arms but it's worth noting that ya might think about getting donor arms if the price is right. Another benefit is that the entire donor can be rebuilt before installation instead of having your rig down for longer than necessary.
An additional note, springs from a bigger engine-equipped rig might be a good idea since your SB has a lil 302.. maybe ones from a 400 or 460 which will have a higher spring rate which can improve handling and address moment weight transfer.
The C-brackets located under the spring... it is sandwiched and bolted over the I-beam. Ignore the Hotckiss decal, it's there for the unknowing:
Fixing the rake...If the days of heavy hauling are mostly over, then consider flipping the rear spring hanger (the front one) for a "half-flip" and adding some pinion shims to correct the induced nose-up angle.. 4° shims should do it. Of course, measure pinion angles before embarking on the endeavor. Links for spring hanger flips are in the Tech Thread Compilation linked in my signature.
If your rig has add-a-leaf helper springs, ya might take a look at removing them for an extra 1/2-inch.
SpacePirate77
38
08-21-2015 11:31 PM
GaRedneck91
19
07-17-2014 01:39 PM
JP78F100Truck
02-23-2014 08:31 AM
USMC0351fordtruckin
06-24-2011 06:43 AM
