PROJECT 53' Aluminator Build
#47
So now that the cab off I worked on the IFS install. The boxing plates need to be mounted square. I measured the frame rails and cut the longer one to match. I had to remove some from the top and bottom. The blue tape is on the bottom and needs to be cut off.
I leveled the frame front to back and side to side on jack stands with shims. Then I clamped the boxing plates on and test fit the cross member. Whoops. Round peg square hole.
The issue is my frame. The bottom of the frame measures correct for width. The top is too narrow. It is actually visible now that I know. The rest of the frame is perfect. But for some reason just past the factory cross member the top of the frame rails tilt in tword each other.
There were a few work arounds I could think of. But I'd rather get the twist out rather than cutting the frame to accept the cross member. I made a little spreader bar out of a RV jack stand I had and some steel 90° channel. Just welded the nut between the channel, and a nut to the threaded part. A few twists with a wrench and it was perfect. Top and bottom the same, and the cross member dropped right in. Nice. Now a level on the side of the frame shows square, as before they were tilted in.
I took it all apart and sprayed the plates and frame with weld through. Then reassembled with the spreader bar. The bar will stay in while I weld. With the plate installed I set the frame to my previously measured rake of 1.5° and set it level in all directions. Then set the cross member in and leveled it side to side, front to back.
Then after I took a break and made sure I wasn't doing something stupid like welding the crossmmber in backwards lol. I re cheaked all my measurements, checked the levels again, then tacked it in. Then welder er up. Well.... I ain't never going to win an award for pretty welds. But they are solid and have penetration. I don't grind them down unless I need to for figment of a part.
I hit up the welded spots with some primer to keep oxidation at bay until I strip the frame next summer and epoxy paint it. I re checked the levels. Good to go. No on to the rear.
#49
I got the rack and sway bar all mocked up. No issues with the tie rods being too short like you mentioned. Did you ever sort that out?
Also the instructions call to c notch the front frame area for the steering arms. I checked on full compression and I still have lots of clearance. Maybe you just need the notches if you use the 2" drop spindles?
#50
nice. I notched mine, but I do have the dropped spindles and have my sway bar in front. my rack was wrong because TCI adds an extension on the drivers side under the boot to compensate for the xmember being off centered and they forgot it on mine.
Are you doing the TCI's four link out back?
#51
Yup. It's just mocked up. I have to get the tires mounted and determine ride height. I have plans for a tubular rear cross member/ drive shaft loop / torque box. But the more I think about it, the more I think I should box it all. Hmmmm.... Got some figuring to do.
#52
I got the tires mounted to the new wheels. Width measurements came out perfect. Phew.
In the process I decided to box the rest of the frame and picked up material to do so. Figured if I didn't do it now I'd be wishing all along that I did. Going to use 1/8" plate. I'll also have to rework the rear coil over perch. So I picked up some 1 3/4" DOM and other assorted sized or 1/8" wall tubing for bolts to pass through the frame.
#53
#55
#56
Honestly that is the one I am leaning toward, I saw a truck at a car show with it and loved it. I worry though about the shocks on the outside of the frame. I want to go with 10 or 12'' wide wheels and I worry I might have clearance issues with those shocks so far out.
#58
#60
I have my E-Stopp parking brake set up here now, and a fuel cell from No-Limit with a return line and LS in tank pump is "in the mail". Hope to have most of the boxing done this weekend.
