having a bad idle and hesitation
as the title says im having engine issues and im running lean, thought it was a vacuum leak but my vac pressure gauge stays put at 14 psi which according to my instructions is spot on for being 7500ft above sea level. all the open and closed throttle tests came back negative for anything. cant be a vacuum leak so now im leaning toward bad fuel pressure. anything else that you guys can chime in on would be appreciated.
I highly recommend checking the fuel pressure as noted above AND running the Key On Engine Off (KOEO) tests and stored code (CM) display.
ive done the KOEO and engine running tests. ive gotten 18, 22, 33, and 41. 33 i know isnt a problem because ive removed the vacuum solenoid to the egr valve and its stuck closed. 18 is my timing (i removed the distributor and didnt mark it so got it pretty damn close if you ask me and ran great for a month until this issue. 22 is something to do with the map sensor and obviously 41 is a system lean.......im starting to think that maybe it could be an air leak with the map sensor going out of range.......any more advice? i wont be able to get to a fuel pressure gauge for a couple days. ordered my own since i cant take time off work to go loan one
Code 18 (CM): IDM circuit failure
Has nothing to do with the base timing. IDM=Ignition Diagnostic Monitor. This is an engine RPM signal to the computer. It uses a 22K ohm resistor to buffer the coil On signal from the Ignition Control Module.
Code 22(KOEO/CM): MAP sensor out of self test range
There is the most likely culprit of all your issues.
Code 41(CM): HEGO sensor circuit indicates system lean
As previously noted for the MAP sensor code.
The computer relies heavily on the MAP sensor to determine how much fuel to apply to the engine. Inaccurate feedback from that signal causes all kinds of issues.
Verify the output with a DVM that can measure frequency. I picked up a $22 USD cheapie at Harbor Freight years ago, works great for this application.
For reference: MAP Sensor
sorry mine was at 36 psi at idle. but when i prime the fuel pump its at 39 or 40. waiting on my new map sensor to see what it does. also i decided to test the iac valve for ****s and giggles and when i unplug the connector the idle only goes down like 100 rpms. could this actually be the problem?
Either someone has jacked with the Idle Stop screw or you have a vacuum leak. Look at the stop screw, it should have thread locker on it. Verify the lock has not been cracked or other disturbed by someone moving it.
If it looks untouched then you have a vacuum leak.
ewalt98
09-06-2014 05:33 PM
4 flat tires
07-08-2011 08:06 PM
eyancey
23
09-17-2009 07:43 PM
