RAD ADDITIVE
Yes you should. It stops you engine from possibly rotting away.
You should drain the coolant and run fleet guard coolant with distilled water.
There is Napakool from Napa Auto Parts, Ford P/N FW-15 or FW-16, and Fleetguard P/N DCA4 that takes care of the coolant additive requirement for our diesels. I'm sure there are more, those are the ones I am aware of.
Reply With Quote Multi-Quote This Message Quick reply to this message
You can get it both ways. And yeah, good that you asked, because the labels are ALMOST exactly the same. You have to look CLOSE at the label to make sure you're not buying half overpriced water.
If you have a NAPA store near by, you can get a 1/2 gallon jug of NAPACOOL and add some to your existing coolant.
Resendiz
41
10-21-2016 12:46 AM
