E4OD Transmission quick fix..
Old 05-27-2015, 07:23 PM
John SCB's Avatar
John SCB
John SCB is offline
The MLPS in my '92 F150 has been replaced twice in 23 years. A couple of weeks ago the transmission started up with the harsh shifting routine. Classic symptoms of another bad MLPS. So before installing another new one, I decide to do a search on this forum. One of the first search results showed a post from someone who said his truck had the harsh shifting when it was wet or raining. He fixed it by just cleaning the MLPS connector and pins. It just so happened to be raining the day my symptoms started! The connector is located in a rather vulnerable position; lousy design. I can totally see how water could get in there to cause problems. Upon disconnecting it, there was some black crud built up. The last MLPS has only been in there a couple of years. So I cleaned it out good and sprayed some contact cleaner in there, let it dry and reconnected. I wrapped the top with electrical tape (where the wires go into the connector) and the connecting components too. It works great! I tried several times without luck to find that original thread to thank whoever it was who suggested this fix. So thank you, whoever you are.
Old 05-27-2015, 10:45 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Before it cruds up again from water, put some dielectric grease in there to keep the water out..
DBGrif91
10-02-2014 08:26 PM
Greywolf
Electrical Systems/Wiring
04-10-2006 11:09 PM
gatorpsd
03-26-2006 03:32 PM
so b it
10-31-2003 03:56 AM
Quick Reply: E4OD Transmission quick fix..
