390 FE Rockers not oiling?
Old 05-27-2015, 02:18 PM
tartar_sammich's Avatar
tartar_sammich
tartar_sammich is offline
Gonna keep this short. Just built a 390 and the rockers on the passengers side are dry. When the rockers are removed, oil pours from the stands. I have holley jets on both sides for restriction and removing them makes no difference. The oiling bolt is in the correct hole. We have rebuilt this set of rockers several times with the same results. Any ideas?
Old 05-27-2015, 02:56 PM
69cj's Avatar
69cj
69cj is offline
Try swapping the rocker arms and see if the problem moves. Will let you know what direction to go next.
Old 06-01-2015, 03:28 AM
Order and Chaos's Avatar
Order and Chaos
Order and Chaos is offline
Any chance the shaft is installed upside down? Or full of crud?
Old 06-01-2015, 07:22 AM
69cj's Avatar
69cj
69cj is offline
If the oiling bolt is in the correct hole to my knowledge the shaft is in the correct orientation.
Old 06-02-2015, 06:59 PM
tartar_sammich
We put a different shaft on with larger oil holes and it works fine now. Not sure what was up with the other one except for the holes being smaller, though.
Old 06-06-2015, 01:03 PM
Jrgunn5150's Avatar
Jrgunn5150
Jrgunn5150 is offline
Is there one bolt that's longer on FE rocker stands?
Old 06-07-2015, 01:04 PM
69cj's Avatar
69cj
69cj is offline
There's one that's hollow for oiling the rockers. It has to be in the proper hole or no oil.
Old 06-09-2015, 10:17 PM
Bret Johns's Avatar
Bret Johns
Bret Johns is offline
8th Gear
No that is incorrect. The shafts will bolt on either way. If the shaft is OEM it has a notch on one end. That notch goes to the front and down on the right bank cyls. #1-#4 and to the rear and down on the left bank cyls. #5-#8 Most of the shafts have 2 holes for each rocker arm. If no notch put them on this way. One set or row of holes should point down and the other row should point towards the push rods. If there is only one row of holes for each rocker, it should point down.
The longer bolt is not "hollow" it is slightly longer 3-19/64" but is "necked down" meaning the neck part of the bolt goes farther down and thus has fewer threads than the others which are shorter 2-31/32" but have more threads.
Old 08-20-2022, 02:51 PM
1970mustang's Avatar
1970mustang
1970mustang is offline
2nd Gear
rocker arm shaft. Did you install it right. There is a notch on each one. That notch needs to be facing down and facing to the front of engine. If not you have no oil pressure
Old 08-21-2022, 10:11 AM
1browski's Avatar
1browski
1browski is offline
That post you are answering is 7 years old. Welcome to the forum. There is one bolt for the rocker arm that has a shaved down shank that lets oil by in the proper hole.
Old 09-29-2022, 07:46 PM
1972-34ton's Avatar
1972-34ton
1972-34ton is offline
...and the two 'thin, long' bolts are towards the middle, but offset from one bank to the other. Also, the oiling holes are chamfered, at least on the C8xx heads.
EDMist
08-27-2009 11:47 AM
Fords&Farmalls
01-17-2008 03:36 AM
parkerusmc
21
11-06-2005 02:53 PM
Trail Master
07-07-2004 07:41 AM
1tom
09-25-1999 02:25 PM
Quick Reply: 390 FE Rockers not oiling?
