Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
49 f1 instrument cluster mounting
Old 05-27-2015, 11:45 AM
johnfin1 johnfin1 is offline
johnfin1 is starting off with a positive reputation.
What do the fasteners look like that mount the cluster into the dash?
Old 05-27-2015, 01:48 PM
Mixer man's Avatar
Mixer man Mixer man is offline
Mixer man is gaining momentum as a positive member of FTE.Mixer man is gaining momentum as a positive member of FTE.
They are metal stand-offs with 10-32 machine screw studs, and are spot welded to the backside of the dash.
__________________
'08 F-350 DRW CC 4x4 6.4, '50 F-6 COE M series cement mixer project, Yuchai bulldozer, Mitsubishi excavator, Mustang skid steer, lots of yellow paint.
Old 05-27-2015, 11:02 PM
The mounting holes in the cluster are about 1/4" in diameter, way larger then 10-32, are there rubber bushings or special nuts?
Old 05-28-2015, 09:35 AM
schoo schoo is offline
schoo is gaining momentum as a positive member of FTE.
Hope you can see the stand off screw with nut
Click the image to open in full size.
Pic of dash can you make out the nut?
__________________
roy
49 F1 under construction
64 F250 4WD
89 F250
Old 05-28-2015, 10:05 AM
Mixer man's Avatar
Wow! Totally different than mine. I'll try to get a pic today.
__________________
Old 05-28-2015, 01:50 PM
Mixer man, you are right, different year, same studs though but the hole in the cluster is the size of the nut. Something is missing, ie a washer or bushing.
Old 05-28-2015, 02:18 PM
Mixer man's Avatar
Here is the backside of my panel before I refurbished it. The gauge studs are #10 for reference. There were no bushings or isolators of any kind. It was a ridgid attachment with lock washers and nuts.
__________________
Similar Threads
After market guages JHarsh 1961 - 1966 F-100 & Larger F-Series Trucks 0 10-17-2014 06:07 PM
Cluster Anatomy JWA 1968-2013 Full Size Vans 8 02-08-2014 06:31 AM
gauge upgrade abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 16 12-11-2013 06:54 PM
Gauge Cluster Backing replacement Mustangking1 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-25-2013 10:21 AM
1980 F150 idiot light upgrade pecanguy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 08-31-2013 08:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
