engine swap
engine swap
I have been posting here a lot recently, but i have decided to give up on my current block. i found an inline 6 out of a 67 F100 with the c4 transmission, long block with everything it needs to run including the belts already installed. mine is a 72 302 with the c4. i know i have to change engine mounts and radiator hoses, but is there really anything more to it than just plugging everything in?
on
You will need to move the motor mounts, but they are the same for the V-8 and IL 6. I had to do it, when I did m chassis swap. Being that the 6 is longer, I think I remember moving them back on the frame, about 1.75 inches... could be mistaken on the distance, but the frame was punched for both the V8 and 6
Baja
Baja
86fordtruck
10-18-2011 08:20 AM
