1996 EASY EXTRA PONIES?
HELLO EVERYBODY, I HAVE A 1996 F150 SHORT BOX REG CAB 4X4 WITH A 302, IM LOOKING TO GET AN EXTRA BIT OF HORSE POWER WITHOUT HAVING TO FULLY REBUILD MY MOTOR, HOPEING FOR SOME SUGGESTIONS, I CAN DO SOME STUFF MYSELF AND IM LOOKING TO SPEND SOMEWHERE BETWEEN 1-2000 ON IT, ITS GOT 186000 MILES ON IT.
Welcome to FTE Jamie, I hope you find the site useful and enjoyable. Please lose the CAPS, as it's the equivalent to screaming at the readers and is considered rude.
Regarding the subject at hand, I'll give you 4 of the cheapest mods for the biggest bang for the buck in these trucks, with the best results:
- Doing the Sixlitre tune up, it involves all-new ignition hardware and advancing the timing some.
- Longtube headers with mandrel bent tubing.
- Camshaft replacement (I'm not very informed about this one, but some others here are).
- Replacing the E7 heads with GT40 heads.
You can do at least 2-3 of those mods with $2000.
Hey thanks for the reply Encho, ive been looking into putting a cam into it but ive heard that you have to mess around with computers, mass airflow, lower intake etc, im also wondering if its even worth it because my motors got so many miles on it (its just started burning oil), i have a spare 302 kicking around at home and im thinking about rebuilding it and doing a motor swap but i dont know yet
302 to 351 swap is pretty straightforward. Your current trans & t-case are fine, no driveshaft changes either. Do a search for "351 swap" and start reading. It has been extensively covered. The same goes for the 351W though: GT40 heads and long tube headers would be a good idea and you'd likely stay under budget (assuming you do all work yourself) if you start with a healthy bottom end. MAF tolerates more extensive mods than speed density, and your 96 is MAF already.
jpeckham
01-17-2013 11:01 PM
jimbo beam
05-11-2009 09:42 AM
