Gauge, or sending unit?
Old 05-26-2015, 05:06 PM
76F100guy's Avatar
76F100guy
76F100guy is offline
The temp gauge on my '76 with 300 barely registers lately. Checked temp with an infrared gun, and it's normal, so it's not a stuck-open thermostat. What's the most likely culprit? And, where is the sending unit? The one for oil pressure's obvious, but can't find this one.
Old 05-26-2015, 05:25 PM
bkaul's Avatar
bkaul
bkaul is offline
If the gauge is moving at all, I suspect the sending unit. I don't know the location of the sending unit on a 300, but once you find it, you can test your gauge: if you ground the sending unit wire, the gauge should go to its maximum position. If it does, there's nothing wrong with the gauge & wiring; if it doesn't, you can try the same test right at the back of the cluster to determine whether it's the gauge or bad wiring in between.
Old 05-26-2015, 05:54 PM
76F100guy's Avatar
76F100guy
Great, thanks for the test info. Did some sleuthing on another forum, and the sending unit is allegedly on the passenger side of the block, up and near the back; not easy to see or access. Guess I know what I'll be doing this weekend
Old 05-26-2015, 06:20 PM
hoss73ford's Avatar
hoss73ford
hoss73ford is offline
My problems with gauges being inaccurate is usually because of the regulator (D1AZ- 10804)
Old 05-26-2015, 08:38 PM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
Check the wiring connector as well. I believe it's a gray four way connector with three wires in it. The wiring is exposed to the elements and can corrode. maybe pull it apart and inspect it as well. If satisfied, stuff dielectric grease in it to help seal out water and crap.
C-220 Connector details:
31 White-Red - Oil Pressure
39 Red-White - Coolant/Water Temperature
16 Red-Green - Duct Tape Hour, erm Ignition Coil + Terminal
Last edited by ZarK-eh; 05-26-2015 at 08:38 PM. Reason: Dielectric Grease to lube things up.
Old 05-26-2015, 08:40 PM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
Which is located on the Instrument Cluster Printed Circuit. AKA IVR or Instrument Cluster Voltage Regulator.
saauvenshine
09-17-2018 02:43 PM
Ripcity
10-07-2013 05:57 PM
areed1
08-07-2006 09:40 AM
hungagain
01-08-2005 09:32 PM
66nut
10-13-2003 05:22 PM
Quick Reply: Gauge, or sending unit?
