C code swap help needed.
I need to get a little information on the excursion x code c code spring swap.My truck started off as a 2002 excursion 4x4 with Pro comp 2.5 inch leveling kit. Drop down shackles on the front and new 2.5 inch procomp rear leaf springs. I've put x codes up front and kept the procomp shackles. I need to see what I need to make the rear level with the front. I was going to delete the procomp rear springs and do f350 dually c codes and f350 4x4 factory lift blocks but I don't believe that will make the truck ride level. Currently I'm at 28.5 inches in the front(center of hub to bottom of fender) and 26 inches in the rear(center of hub to bottom of fender). From my research factory 4x4's are 24 inches front and rear. So I have 4.5 inch lift up front and need a 4.5 inch lift in the rear. Also if it matters I have hell wig rear anti sway bar. I really appreciate any and all info. Thanks
I run modded B codes rears using the typical mod of the 2 bottom EX leaves and the thicker EX between leaf spacers. In addition to that I also used the taller F-350 tapered blocks and 2 sections on each side of the old EX slapper traction bar cut down between the blocks and springs. This setup gives me 28 1/2" from the hub center to wheel well lip.
My rear modded B code spring, block and spacer setup.
Xcursion88
1999 to 2016 Super Duty
07-29-2017 07:03 PM
bigwhitetruck01
05-27-2012 03:45 PM
jeeplj8
03-23-2012 10:52 AM
