Mixing a low pinion and mated t case
Old 05-25-2015, 07:50 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
Has anyone else ever tried using a low pinion 44 with a truck that has a mated t case? I'm getting a truck that doesn't have a front axle so I'm going to sit my old 44 under it for now at least. Is it possible to have a workable pinion angle like this? If I can make it work I might just let it in there.
Old 05-25-2015, 07:51 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
Forgot to mention it will be stock 1978 height not lifted at all.
Old 06-03-2015, 10:33 AM
Joseph69's Avatar
Joseph69
Joseph69 is offline
I think your first problem would be the transmission cross member, not sure if the lower drive-shaft will hit it. The pinion angle would be okay but a low pinion 44 usually comes with older, weaker parts.
Old 06-03-2015, 11:51 AM
PA74F250's Avatar
PA74F250
PA74F250 is offline
It actually does seem like it's going to work as long as I don't lift it. I have to use a 79 F350 front driveshaft because it's a little shorter. I tried a 79 F250 shaft that was used on a hp 44 and I have no room to move its collapsed all the way. I wish I had another HP D60 laying around but I'm going to keep my eyes out for a HP44 since this isn't exactly ideal.
VaFordman26
11-20-2018 04:28 PM
KsHighboy
06-23-2016 05:17 PM
dillinewton
Offroad & 4x4
31
06-16-2014 09:05 PM
3Mike6
08-09-2007 03:03 PM
fomoco3904
Offroad & 4x4
04-03-2007 10:02 AM
Quick Reply: Mixing a low pinion and mated t case
