Computer blew up
Old 05-26-2015, 12:34 AM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
Originally Posted by NotEnoughTrucks2014
Yes, you are correct. My old eyes deceive me from time to time. Interesting thing about the remaining lead from what may have been a large diode is that it looks undamaged while the bulk of the diode and the opposing lead seem to be disintegrated. That would tell me the device was not destroyed by current through it, rather from some event isolated to the one lead. Would be very interesting to see the board up close and try to power it up. Usually a diode of that size is employed for polarity protection. Nothing else in the box would need that size of diode.
for something of this vintage, it's probably for polarity protection of either the processor, where the memory bank. The picture isn't detailed or large enough for me to trace the circuit to either area. But yeah, that thing is toast. On these old PCM boards, sometimes you can get away with replacing one component everything is OK. But I have the feeling that whatever that diode is protected is also toast.
but what the hell do I know, I don't deal with printed circuit boards when I work on electronics, if it doesn't have a turret board, a transformer that weighs about 20 pounds, and vacuum tubes, I don't touch it!
Old 05-26-2015, 08:04 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
NotEnoughTrucks2014 is offline
Like them tubes do you? I hear ya!
Grew up fixing radios and TV's in my dad's shop. You haven't lived till you've taken a hit from a charged capacitor in the plate supply circuit!
Had the pleasure of meeting this man back in the 90's.
History of the Garnet Amplifier Company - garnetamps.com - Home of the Garnet Amplifier Company
Way off topic, of course, sorry OP!
Old 05-26-2015, 08:09 AM
GuitarJesus
Oh yeah, I hear you. I've taken a hit from a filter capacitor array, I swear I saw the bright white lights for about 2 minutes after that. 500+ volts at who knows how many amps.
Old 05-26-2015, 07:57 PM
weskan's Avatar
weskan
weskan is offline
I don't think moisture got in. It is pretty dusty on the top side. I'll get some closer pics a little later. It looks to me to be a rather dramatic capacitor leak that discolored the diode.
Old 05-26-2015, 10:11 PM
weskan's Avatar
weskan
weskan is offline
Old 05-26-2015, 10:13 PM
weskan's Avatar
weskan
weskan is offline
What I thought was wet on the bottom was just the shiny surface of the coating they used.
Old 05-26-2015, 10:34 PM
nwjones18's Avatar
nwjones18
nwjones18 is offline
I just put a computer in my 89 bronco. As far as I could find the Cardone reman computers from advance are the best deal since you can use a $40 off coupon and get free shipping..
Old 05-26-2015, 10:40 PM
weskan's Avatar
weskan
weskan is offline
I already ordered a NAPA unit. I was leery about the Cardone units since most reference about them was bad. Granted most of those posts were 5 to 7 years ago. I also got a bit of a deal with a corporate discount because of the company I work for.
Old 05-26-2015, 11:34 PM
nwjones18's Avatar
nwjones18
Just out of curiosity I looked up the computer I got at advance on Napa's website then clicked on the warranty information. It seems that Napa's computers are Cardone's anyhow..
http://s7d9.scene7.com/is/content/Ge...39940pdf?$PDF$
Hope the computer solves your problem! Mine has been running well since I swapped them out.
Old 05-27-2015, 08:01 AM
NotEnoughTrucks2014
Interesting pictures.
So that diode did survive. Never would have guessed from the first picture. Whatever happened there has actually burned into the circuit board. If you take a pick and scrape at the blackened areas, you would find that the circuit board material has actually carbonized. There will be significant destruction and pitting of the circuit board material.The normally insulating material becomes conductive when this happens and the whole situation cascades. If you catch it live, it looks like a tiny welder arc and it is really destructive to the circuit board. Of course, this is no longer a repairable condition, at least not with any degree of reliability.
There has to be a trigger event that starts this process. I don't think it was the nearby capacitor. The bottom was burnt, but I think that is the result of the heat generated by the circuit board burning up. The top of the can still looks flat. If you look carefully, there is a Y shaped score on the top of the capacitor. If the capacitor fails, it will heat up and the electrolyte will boil, pressurizing the capacitor. There is a vent on the bottom side and the top is designed to blow out, relieving the pressure in the event of failure. The contents of the electrolytic capacitor can be messy, but they are not conductive, so I don't think it will be the culprit. Component failure can cause circuit board traces to heat up and start this process, but you would find signs of damage extending along the traces from the damaged area. I don't see this in the pics. Sometimes, transient voltages can arc across closely spaced printed circuit connections and start this process, or a soldered connection may fail due to vibration and overheat. It looks like there is a pit near the capacitor that has a solder through eyelet in the center and that is likely where the destruction started. It's only speculation as to the cause, but I would go with the transient voltage spike. These ECU's are really well designed hardware and the fact they have lasted over 20 years already speaks to their quality, but everything has a life cycle. I'll agree that we likely will see more of these systems fail in the coming years. Hopefully it won't become a problem limiting the usefulness of our vehicles.
Old 05-27-2015, 08:13 PM
weskan's Avatar
weskan
weskan is offline
Another destruction pic. This time from the other side of the board. Looks to me like something other than the capacitor went bad.
Old 05-27-2015, 08:16 PM
GuitarJesus
Well if its a Tantalum Electrolytic capacitor, it's filled with sulphuric acid. That'd do it.
  #28
Old 05-27-2015, 08:25 PM
weskan's Avatar
weskan
weskan is offline
Here are some pics of the inside of my replacement eec. Looks like they only replaced the capacitors because that is the only place there is a disturbance in the coating that Ford put on it. It is already installed and it runs just fine. The paper in the box with the replacement ecm didn't mention the rebuilder but the warranty pdf on NAPA's website is from Cardone.
  #29
Old 05-27-2015, 08:30 PM
weskan's Avatar
weskan
weskan is offline
Rebuildable or not, that smelly hunk o'junk is worth $78, so off it goes and hopefully closes out this little saga.
  #30
Old 05-28-2015, 06:55 AM
dixie460's Avatar
dixie460
dixie460 is offline
Interesting damage. I'd say something flashed over, but that does take some voltage to make it happen... more than I'd expect to find in a PCM.
Glad you got the truck running again.
PooreBoy
Washington Chapter
08-20-2010 10:36 AM
4tl8ford
16
07-27-2009 08:48 PM
rostena
137
09-01-2008 07:20 PM
mjwhip2
Offroad & 4x4
16
11-03-2004 03:43 PM
Quick Reply: Computer blew up
