Are Fox 2.0s worth it?
They are much more expensive than Bilstein 5100s, a little more than Rancho 9000s.
Pros
1. Build quality looks much better than most
2. Legendary Fox name
3. Serviceable (by Fox)
Conns
1. Only 1yr warranty (vs almost everyone else providing a limited lifetime)
2. More expensive
3. Perception that they will ride harsher (due to more Performance based perception)
4. Serviceable by Fox only
My question is, how do they ride, compared to Bilstein and Ranchos? Should I be concerned about the 1yr warranty?
I am looking for comfort more than anything.
Pros
Conns
2. More expensive
While I have never read a review of the Fox shocks for a Ford superduty, I am becoming very impressed with my newly installed Rancho 9000 shocks as I get them more dialed in for my driving conditions, local road surfaces, and preference.
I read your question more than a few times, and to be honest under the list of PRO comments I don't really seen any PROs listed.
Legendary name............but established in an entirely different vehicle use and variety of specialized off road sports.
Serviceable only by FOX, what kind of service are you speaking of? Shocks don't really require any service. Either they are good and do their job or they are bad and get replaced. With a one year limited warranty what's to service.
Build quality better than most?
But then I really do no driving that would benefit from having shocks with a reservoir for dampening control.
I paid on average $85 per shock, maybe $10 shipping and a $106 rebate from Rancho being processed.
I'll not try to talk you into any manufacture product line that's a personal preference as well as wallet based. I'm just saying that I am pleased with my choice and becoming more so the longer I have them.
If you do go with the FOX shocks please do come back and post a review, I would be interested in reading it.
I just got off the phone with a really cool guy from Fox. He was very knowledgable and explained a lot. They are very proud of their manufacturing process and spend a considerable amount of time fine tuning their shocks before selling them. He also stated that if they wear out, the cost of rebuilding them is generally less than a cheap shock. That was reassuring.
He made a really good point also. He said that their shocks are so good that most of the competition actually offers Fox 2.0s as an special order, premium upgrade on their lift kits. I found that to be true.
Don't get the rancho 9000s I used to run them and its a constant mind game of "oh I can adjust them and it will be all better " there are many situations that I've found that the ranchos cannot react fast enough and you get a weird wobble feeling from the rear end because they are not a charged shock they are foam and oil filled like a factory shock or a steering dampener , I've seen good things from the MX 6 on the half ton segment but I'm sure they change their valving for the light truck segment as far as the bilstiens they ate legit you can't loose with them and they have shaft covers which are cool but they don't do well inverted if you like that look and fox is only inverted
This individual is misinformed. The RS9000XL is a charged shock, just not as high as a monotube shock. They used to be foam but no longer. A monotube style shock can be inverted too. Look at various Jeeps out there running a monotube style with the rod down. We prefer rod up to protect the rods from nicks.
Another thing that sets us apart.
PERFORMANCE GUARANTEE AND 90-DAY RISK-FREE RIDE OFFER
We challenge you to try our Rancho® RS9000™XL, RS7000®MT or Rancho® RS5000™X Shock Absorbers risk-free for 90 days - if these products* don’t meet the challenge, call us for your money back.
Just wanted to clarify this.
They are the same style as a Bilstein, and a Fox 2.0, a monotube shock.
But our valving and gas charge is different, as all companies will set up their shocks differently.
After a good cleaning and fluid change, shocks feel like new again.
Don't confuse crimped/pressed/welded together non-rebuildable throw away shocks, with a high end rebuildable/serviceable unit....
I run Fox shocks on another vehicle and love them. They're expensive though...
jmo
I think I'm going to like my Fox shocks when they arrive. I'm excited to review them and really see if they make a difference. I might even do a video review showing a water glass with a level indicator and take the truck on a few paved and dirt roads to see water loss. I'm really more interested in their performance against my current Skyjacker M95 shocks.
I spoke with 4WheelParts today and their suspension expert has sold a ton of pretty much everything. He says that the Fox 2.0 is an exceptional shock as is the Bilstein 5100 and 7100. He puts them at the top. He says he actually pushes the Skyjacker m95s quite a bit for customers who want the performance of a 5100 without the cost. He claims it's a very good Monotube and the best Skyjacker has to offer
He said the Rancho 9000s are great shocks but has heard of them rusting pretty bad in certain climates and they tend to last about 40k miles before needing to be replaced. He pointed out that they are a pretty expensive shock to need replacing instead of offering a rebuild option like Fox does. Interesting point.
I'm still very interested in all of them, but I have already ordered the Fox shocks, so will see how they affect my ride.
A few more things! Ha!
I would hit the shock bodys of the the 9000's with a clear coat to add more protection against road grime.
I would also look to a Fluid Film type for the shock bodies of a monotube too. I have seen ALL types of shocks look nasty.
Shocks typically last around 50K, maybe more maybe less depending on various factors.
Lastly if they do need replacing, keep the receipt. They are covered by our Limited Lifetime Warranty.
LIMITED LIFETIME WARRANTY (limited to qualifying Rancho® products only)*
Tenneco warrants qualifying Rancho® products against defects in materials or workmanship (except finish) when used under normal operating conditions for as long as the products are installed on, and the original purchaser owns, the original vehicle on which they were installed.
In regards to cost. It will be tough to bet the 9000's with the rebate.
Promotions
Good luck with the Fox's!
Promotions
Promotions
Promotions
I just look at the exterior build quality of the Fox and they look exceptionally well built. Plus their following seems to be very loyal. I've used Fox shocks on my mountain bikes along with Marzocchi for along time. Their performance has always been amazing and even saved my butt more than a few times. So I trust their manufacturing process. I've never owned a vehicle shock from them though and really am looking for honest and frank feedback.
