I have A 90 bronco That had the 351 Windsor in it I have since put a a 302 in it everything seems to be fine other then when u put it in gear it looses power. What in the world could be doing this computers have been changed relay switch changed! Please help
Do you mean the idle drops when you put it in gear? Or does it have no power when you press on the accelerator? Have you pulled codes since you changed computers? Did you change out the wiring harness and sensors too?
Yes we believe we may have found the problem it's the relay all was changed the wiring harness. Sensor, computer, everything we even went as far as to cut the exhaust. As soon as u go from park to reverse or drive it looses power. Idles great.
Nope he did not change the wiring harness! I thought he did
