Transmission problems
Okay, did a body swap on a 77' last weekend. Got all the bugs ironed out and took it for a ride last night. Went about 15 miles and the truck stopped shifting and dropped speed. Pulled over, added tranny fluid and truck took off, but did not act like it was in first gear. Towed it home,
This morning, found blown transmission line to the tranny cooler, replaced it and added fluid. Truck goes into all gears, but you have to rev the motor high to get it to move (almost as if you were starting in fifth gear in a manual)... Does this in all forward gears and reverse.
Any ideas?
Any ideas?
I don't know for sure. But yes I think that could very well happen.
You didn't say how much fluid you had to add back in
And I'm not familiar with the history of the transmission, so I'm only guessing.
If it was weak/old / high miles to begin with? If the fluid was old and nasty to begin with?
If it started puking right away it could have been empty in 15 miles probably less.
No fluid in it while driving obviously isn't a good thing and it could have kept you going
for a mile or more with nothing in there and than poof.
You could check to see if a vacuum line busted off someplace.
If all lines look good drop the pan and look in it for any possible clues.
It's been a long time since I dealt with auto transmission problems. Fortunately I suppose; since my vovo one is high mileage and doesn't even have a filter :/
But usually they either work or they don't with these types.
If it was completely empty and driven on as you imply, than only a rebuild is going to fix it. Someone else hopefully will over rule my opinion with better news though.
Like he posted? Absolutely. With no line pressure, but rpm, it will attempt to apply the clutches, they'll just slip, and burn. It's not like it popped the line and died immediately, I'll bet, he revved it quite a bit, then added fluid, drove some more... poof, clutches gone.
on
That's Terrible! ... Glad I drive a stick even gladder now!
Except, If I keep grinding my four gear
U9000
01-30-2019 11:34 AM
GM4WALLS
05-28-2015 04:33 PM
wesford
09-30-2007 09:46 PM
Cougar64
05-07-2005 12:46 PM
FixOrRepairDailyinOH
1983 - 2012 Ranger & B-Series
15
10-06-2004 11:20 AM
