2006 F-150 V8 XLT SuperCrew - LED Lights Installed, having electrical issues
Old 05-24-2015, 05:16 PM
BrdNV82's Avatar
BrdNV82
BrdNV82 is offline
In advance, I just want to thank everyone on here for the great feedback and help you provide. I have tried to list all the details that I have for this problem, so if there is anything more you need to help me out with this, please let me know.
I have a 2006 Ford F-150 V8 XLT 4x2 SuperCrew that I had to replace a few old/blown bulbs on (left Front Blinker and rear Right Blinker/Brake). I decided to go with the Pilot brand LED replacements, and verified that they are the correct replacement models to the factory bulb part numbers.
Per what I've read from others' experience doing this... I opted to buy the EP27 flasher to fix the issues with hyperflashing, rather than going with Load Resistors. So, all LEDs blink/flash with no problem.
The issue seems to be related to me having the Headlight Switch in the DRL-on position, and the headlights/parking lights not being on (i.e. if it's still daylight and it's just the DRL). If the Headlight switch is left in the off position or in the DRL-on position, when I brake or signal (left or right) the entire electrical system will flash/illuminate with the brake/flashing activity (this includes all LEDs and brake lights and the Stereo backlighting... anything that is dimmed by leaving the Headlight switch in an 'off' or DRL-on position). The only way to fix the problem is to turn the Headlight switch into the parking or headlights on position.. then the issue doesn't occur, all signal and brake light activities work as expected.
It's not a big deal, but I guess I'm lazy and like having the headlights come on and off automatically... plus, I'm a little worried that there might be an electrical issue that could cause me issues if I don't address it now.
The only thing I have NOT done is replaced the LEDs back with Incandescent bulbs, to see if the problem is totally eliminated. I have verified that no fuses are blown in the fuse panel, etc.
I'm sure the issue is easy to fix and I'm hoping the fix isn't to remove/replace the LED lights with OEM lights.. =)
Thanks again for any help you can give me. I really appreciate it.
--Brian
Old 05-24-2015, 05:19 PM
Trailblazen's Avatar
Trailblazen
Trailblazen is offline
Hey buddy, you posted in the 2009-2014 F150s. You may want to try this in the 2004-2008 section. They are probably more versed in this year.
Old 05-24-2015, 05:24 PM
BrdNV82's Avatar
BrdNV82
BrdNV82 is offline
Ah crap, sorry about that. I'll repost - thank you!!
Old 05-24-2015, 05:28 PM
Trailblazen
No worries friend. Just wanted to make sure you got the help you needed.
Bacon604
2004 - 2008 F150
05-29-2013 06:23 AM
fixitman1310
05-01-2011 08:46 PM
jacksonford
11-20-2010 01:11 PM
bigreave
Electrical Systems/Wiring
08-20-2003 06:35 PM
Quick Reply: 2006 F-150 V8 XLT SuperCrew - LED Lights Installed, having electrical issues
