gauge cluster replacement
i just bought a 00 f250 cc that originally came out of Canada so the speedo and mileage is all in kilometers. i have bought a use cluster that is in standard units to replace it with. i am just curious if all i have to do is replace the cluster or if there is other thing that need to be replace as well to make it work right.
No you can not use the digital (01-04) cluster with the older style (99-01) vice versa.
I went back and reread through it, I hope i'm not reading incorrectly and giving miss info.
My gauge cluster is the top pic showing that its for 99-01. The lower pic is 01-04. You can only use the same cluster in swap.
on
The dealer can change the millage, You have to sign a wavier stating that what you say is correct and it stays with the dealer, they just burn the chip they need the cluster not the whole truck.
Jghake
03-30-2018 11:36 AM
Mustangking1
11-25-2013 10:21 AM
