Questions on replacing door glass - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Log In
Old 05-24-2015, 01:12 PM
Jacnat's Avatar
Jacnat Jacnat is offline
Jacnat is starting off with a positive reputation.
I have a couple of random questions for anyone who has done this. I am replacing the window regulator (had a broken weld and couldn't be salvaged) and replacing door window glass. So my questions are: 1) do I attach the window lift channel to the new glass before putting glass through the access hole? I assume so but the shop manual doesn't say. 2) do I put glass in through the access hole before installing the new regulator? Thanks for the help.
Old 05-24-2015, 03:43 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
1 yes
2 I think so
It's been awhile since I did one. It becomes obvious as you go. You'll likely end up shifting things around a bit. Loosen the division bar to gain some flexibility. Patience is your best friend on this project - good luck!
Old 05-24-2015, 03:44 PM
Doc's Avatar
Doc Doc is offline
Doc is a splendid one to beholdDoc is a splendid one to beholdDoc is a splendid one to beholdDoc is a splendid one to beholdDoc is a splendid one to beholdDoc is a splendid one to behold
Answer to #1 is yes. Definitely attach the window to the channel first. Answer to #2 is no. You can put the glass inside after you install the regulator.
__________________
Shane
1949 F1, Stock / 1950 F-5
1950 F1, 302, AOD (still in a lot of pieces)
1997 F150 XLT, 4.6L
2011 F150 FX4, 3.5L Ecoboost
2011 Expedition EL
Old 05-24-2015, 04:42 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold
If the regulator is not in place to attach the glass to, it will end up sitting at the bottom of the door, and in the way installing the regulator through the access hole. My 2c.
__________________
Wayne
52 Mercury M-1
among other things.
Old 06-04-2015, 07:40 AM
Jacnat's Avatar
Thanks to all who responded. It took a couple of hours but I got the side-window in and it's working great.
Similar Threads
Front door glass replacement wallz Excursion - King of SUVs 28 06-25-2015 06:28 PM
Vent window install johnson.jeff.a 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-04-2015 10:09 AM
These trucks are so much fun ! DR Smith 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 10-11-2014 07:05 PM
'51 door glass question wallster 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 01-03-2014 11:33 PM
"New" 47 Ford truck, door glass question bigf350sd 1947 and Older Ford Trucks 14 02-08-2013 08:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
