Battery cable Terminals
I have had great luck at NAPA. Buy a new ring terminal, and ask the counter guy for a solder pellet for the size wire you are using. Put the pellet in the end of the terminal then push in the stripped wire. Heat the new ring with a torch till the solder melts. I then would use heat shrink tubing over the end. I chose a brass terminal over the lead style.
Boaterguy
6.7L Power Stroke Diesel
28
08-29-2018 12:47 PM
coolfeet
11-28-2015 11:10 PM
jmo1112
12-29-2014 02:44 PM
