Hi Bronco fans. I have 1967 with a 302. I want to put manfolds on it, my friends had a old ford truck with a 400 in it . Does anyone know if they will fit a 302. Thanks for all your help Rick
351W is pretty much the same heads, but the blocks have a taller deck, so intake manifolds won't interchange (the 351W heads are farther apart than the other Windsor engines). I believe that you can swap exhaust manifolds between the 351W and the smaller Windsors, but the outlets are different. I think I've heard that makes it more trouble than it's worth to try to swap them.
But broncosport is right, the M manifolds are different.
I am assuming you are talking about exhaust manifolds and not an intake manifold. No- 351/400m will not fit. 302 truck manifolds are easy to find and pretty cheap compared to some car manifolds like a 351w or 351c. Check ebay-expect to pay around $125
