Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
9 inch rear gears
Old 05-22-2015, 09:49 PM
atlanta1020 atlanta1020 is offline
atlanta1020 is starting off with a positive reputation.
9 inch rear gears
I drive a 1976 ford f100 2wd, c6 with transgo shift kit, 9 inch rear with 3:73 gears, limited slip, 31x10x15 tires. My rpms at 60 mph are 3000, I feel that it's a little too high, I mostly drive around town but when I do drive on the highway over 65mph it's loud. I was thinking of going with 3:25, I don't know if the 3:50 will make much difference from the 3:73s. Any suggestions?
Old 05-22-2015, 10:09 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Click the image to open in full size.
Old 05-22-2015, 10:40 PM
ultraranger ultraranger is offline
ultraranger has a good reputation on FTE.ultraranger has a good reputation on FTE.ultraranger has a good reputation on FTE.
Just for clarity, Ford didn't offer a 3.73 ratio in the 9-inch rear ends. The closest you would have gotten to that in a factory ratio would have been a 3.70.
Not much difference from a 3.73 but, will make some difference in your calculations.
Old 05-22-2015, 10:51 PM
HIO Silver's Avatar
Lemme find a Ford 9 table.... BRB.
... dagummit. Can't find one.. Oh well, just use the table above for guidance, ya know? Or swap in an 8.8 and then the table will be spot on! LOL.
Old 05-23-2015, 10:19 AM
Formula for calculating engine RPM for a given tire height, gear ratio, transmission final drive ratio and MPH.
RPM = MPH X Trans Ratio (in high gear) X Rear End Ratio X 336 ÷ Tire Height.
....or, you can just do it the lazy way and use this handy dandy RPM calculator that will compute the factors for you.
Engine RPM / Engine Speed Calculator
Old 05-23-2015, 11:33 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
AXLE code stamped on the 2nd line-far right of the Warranty Plate, riveted to the left door face below the latch.
If the AXLE code begins with a letter: Limited Slip (L/S). If with a number: No L/S
1973/77: 09 = 3.70-1 without L/S / 1975/77: H5 = 3.70-1 with L/S
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
Old 05-26-2015, 12:03 PM
wdfp wdfp is offline
wdfp is starting off with a positive reputation.
I had pretty much the same setup you do after I put what I thought was a 3.50:1 locker in my 77. But it is closer to 3.90:1 and it would not hit 3000 rpm until 70 mph. I have since put the original 3.25 trac-loc back in it and it made quite a difference. I think you have something off like the speedo or tach maybe because you should be around 2500 2600 rpm at 60 mph The 31x10.5x15 will make your speedo read slower if nothing else was changed.
When I went to the locker it changed the speedo reading almost back to what it was before I went to the 31" tires which are only 30 in reality. A lot closer to accurate anyway
Old 05-27-2015, 01:39 AM
I originally had an open diff with 3:00. When I replaced it with a LSD 3:70 I also replaced the speedo gear. I cant recall how many teeth it had but it was orange and preplaced it with a white one. I might of use the wrong speedo gear that's why its not accurate.
Old 05-27-2015, 12:09 PM
Jrgunn5150 Jrgunn5150 is offline
Jrgunn5150 is starting off with a positive reputation.
Before GPS on every phone, I would check my speed by timing a mile on the freeway.
Old Yesterday, 12:39 AM
well I downloaded a speedometer on my iPhone to check my speed. My trucks speedometer ended up being off. I'm at 2500 rpm at 60 mph. The speedometer seems to be accurate until I begin to go over 50 mph. thanks for all of your help.
Similar Threads
F-1 Rear end 3.73 ratio 49willard 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-12-2015 08:16 PM
2002 f350 axle fitting 95 f250 HD? makattack 1987 - 1996 F150 & Larger F-Series Trucks 1 03-01-2015 08:22 AM
Why not both trucks 2K rpm at 70mph? Snowseeker Super Duty & Heavy Duty 4 10-13-2014 07:19 AM
gear change questions chavist93 1987 - 1996 F150 & Larger F-Series Trucks 7 09-28-2014 11:12 AM
Best source for front axle gears 3360stepp 1961 - 1966 F-100 & Larger F-Series Trucks 9 08-16-2013 08:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
