transmission issue?
Old 05-22-2015, 09:42 PM
ramirez7589's Avatar
ramirez7589
ramirez7589 is offline
transmission issue?
Have a 2004 F250 crew cab with the notorious 6.0L.. ive noticed what i believe is my tranny or maybe torque converter.? What happens is when i back out the drive way and the go into drive, i hear and feel a rough loud clink down under even when im at a stop sign.. Any ideas im a first time truck and diesel owner due to my field of work. Also it has a rought time starting in the mornings or anytime the truck is completely cold. Then after it warms up it behaves like it should. also ill get on the throttle and when i come to a stop, the idle is rough and slowly comes back to normal. ...???
Old 05-22-2015, 09:48 PM
04badford's Avatar
04badford
04badford is offline
Any repair history ? like last tranny flush, oil change so on , take a look at the carrier bearing, u joints, if 4x does it do it then aswell or just 2x? as far as the rest Do you have a Gauge ? like scan gauge or a I phone to add a app.
Old 05-22-2015, 09:50 PM
04badford's Avatar
04badford
Check FICM volts cold start there is a test procedure in the tech folders another reason to have a scan gauge
Old 05-23-2015, 02:16 AM
ramirez7589
Mainly in 2wd. Its pretty lloud clinck. sometimes it wont clink till im going about 5mph. Sometimes as soon as i press the gas pedal. And whats the app you speak of. I went to grease monkey about a month and a half ago. Worst choice ever. Im due here soon . This time ill do the oil change myself. along with engine oil filter and fuel filter. I have some hot shot secret that im going to try out for the first time.
Old 05-23-2015, 07:02 AM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
You have allready received good information but Mark Kovalsky will be the man to talk to
He worked on the actual developement of the transmisson in the 6.0.
Old 05-23-2015, 08:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
The problem is in the driveshaft. There is a slip joint that is dry. Ford sells a special grease for this. You need to take the slip joint apart and slather it with the special grease. Regular grease will work, but you'll have to do it again in a couple weeks.
Old 05-23-2015, 06:12 PM
04badford's Avatar
04badford
You have some things going on , Charging system needs to be looked at Battery's, Alternator for start your FICM cold don't want to see anything below 45v on a good system 48/49 all day long. Thank you Mark for chimeing in , why is there not a grease Zerk for this area , My Tractor slip yolk has one you would think ford Oh never mind
Old 05-24-2015, 10:07 AM
bizzelj's Avatar
bizzelj
bizzelj is offline
Not to hijack but I have had the same problem for a few weeks now I took it to a mechanic they threw parts at it about 700 dollars and it still does it. Were can I get this grease at and how hard is it to take off?
Old 05-24-2015, 11:58 AM
Mark Kovalsky
Any Ford dealer will have this grease. It's blue.
It isn't hard to get to. You need to remove the driveshaft and lube the slip yoke. There are different slip yokes depending on 4x4, 4x2, long bed, short bed, standard cab, crew cab, extended cab, and all the permutations of the above.
Old 05-24-2015, 01:17 PM
69cj's Avatar
69cj
69cj is offline
You can also use the blue marine grease. It has fibers in it and sticks very well. The fibers also seem to have a cushioning effect. At one time there was talk of drilling the outer joint and installing a zerk fitting for future maint. I don't recall anyone coming back and saying that the zerk created a balance problem.
Old 05-24-2015, 03:46 PM
bizzelj's Avatar
bizzelj
bizzelj is offline
You talking about this stuff?
Glaser67
01-11-2016 07:47 PM
9000_red
10-13-2015 10:30 PM
RedLang
01-13-2012 11:11 AM
Grunter
11-05-2005 01:58 PM
"Eddie_B_Bauer"
Oil & Lubrication
02-09-2004 11:46 AM
Quick Reply: transmission issue?
