Engine noise
I can almost guarantee a 1977 engine has cracked or broken piston skirts. These pistons have a steel strut cast into them to help control heat expansion. Unfortunately the struts introduce stress points which eventually lead to cracked skirts. The good news is that the engine can survive many thousands of miles with broken skirts.
Modern hypereutectic replacement pistons are much stronger and need no steel struts.
It could be another cause, like a timing gear getting ready to go, or even carbon build-up in the combustion chamber.
If it was me I'd throw some additives in the oil and fuel. Then search for and pick up a good rebuildable engine core. And just drive the one you've got in there until it craps out or you get the other engine finished. That way your truck isn't down anymore then it has to be.
Yup. Here's a little trick my boss taught me.
Fill a gallon jug with water. Hook up a 3/8 hose to your intake manifold and run the hose into the passenger compartment. With a warmed up engine sit behind the wheel with the jug o' water between your legs and the end of the hose in your hand.
FLOOR IT - yes WOT.
Before the engine reaches redline plunge the end of the hose in the gallon of water. The engine will start to bog down as the water enters the hot combustion chambers and instantly steam cleans everything in there. Modulate the engine speed by withdrawing the hose and plungeing it back in as the revs increase until the gallon of water is gone - passed out the exhaust pipe.
Change oil.
Clean the carbon soot off your driveway or garage floor.
FLOOR IT - yes WOT.
Change oil.
TCornehl
05-22-2005 02:45 AM
mikeil888
09-27-2002 01:28 PM
