Another new problem.
FYI; I'm almost to the point of giving up on this truck.
In the last 3 weeks I've replaced the oil cooler. IPR, ICP, fan clutch, intercooler, rebuilt the turbo, new elc coolant, egr valve, thermostat, new batteries, positive battery cable, and alternator and a host of other crap. Now I have a new problem.
When towing it overheats, almost instantly under load. I was towing a 9k trailer up a hill, a total of about a 30 second climb and it overheated (242 degrees). I'm thinking head gaskets at this point as they are stock and have the tty bolts installed.
Yes, it cools off fairly quickly. On another note, it got up to 222 and would not cool off earlier, even when stopped.
Now, even under no load, it gets to 200+ under mild acceleration. It also has a lot of pressure in the cooling system when I unscrew the cap. No oil in coolant or vice versa. I don't have any puking or white haze under cap either.
No, and that's the funny thing. It gets hot, yet loses no coolant. On inspection, the pressure in the degas bottle seemed normal as compared to the previous V10 truck I had. I'm leaning more towards a water pump or thermostat at this point. There's literally no indication of a head gasket failure.
heard that this messes with the fans typical operation.
also the t stats on these trucks tend to stick open rather than closed but is a possibility for sure.
you are supposed to have pressure in your degas bottle. (raises the boiling point of the coolant / water)
could be the water pump too, im not sure if the water pumps on these trucks have a weep hole or not. im sure they probably do though but dont quote me on that lol
weird. do you have your EGR valve blocked off or unplugged?
I pulled the new OEM thermostat and it seems sticky. I replaced it with a stant unit (all there was around me) and now it hovers around 195. I can get it to go to 200 by punching it for a few blocks. I also noticed that the FMP voltage is fluxing between 45.5 and 49 volts randomly. The coolant coming out of my coolant filter is a very slow trickle and the filter is new. I'm thinking my coolant pump is failing.
also need to check out your batteries and charging system.
any lower than 45.5 and your looking at probably needing an FICM too.
