Painting a 300I6.
Old 05-22-2015, 01:47 PM
Viperfoxbat's Avatar
Viperfoxbat
Viperfoxbat is offline
Painting a 300I6.
I plan on washing the motor down and getting the crud off.
And cleaning underneath too. Then I plan on changing all the wires ,plugs,and things that need changing. After all that I want to paint the motor back to original.the sides and the bell housing
Are black and the top of the motor is ford blue.could I do it without removing the motor? I plan on tieing. plastic bags around parts I do not want painted.pluse wrap up things I do not want painted in news paper. What kinda paint do I use?and where is a good place to buy it?
Old 05-24-2015, 12:04 AM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
Not sure about procedure, but I used engine paint. The idea is that the heat of the motor fully cures the paint to a hard finish.
I used rustoleum engine paint from a local canadian tire and painted mine New Ford Grey with some kinda Red on the valve covers and oil pan. I wanted Black, but the Son didn't like that and convinced me to use another colour, and he picked the red.
Trick is prep work, and getting the surfaces clean! I used paint prep in the same aisle at canadian tire, and smelled a lot like Methy Ethyl ketone...
Old 05-24-2015, 09:50 PM
Viperfoxbat
That's all it is denatured alcohol .we use to use it in painting transformers.thanks I have been looking at paint guns .i plan on buying a three set one for primer and one for paint.the other is a touch up paint gun.i plan on buying a da sander ,roll of sand paper .and some filler incase of rust or dents.so most of the work is in the side of the bed.
Old 05-25-2015, 08:40 AM
The Frenchtown Flyer's Avatar
The Frenchtown Flyer is online now
Originally Posted by ZarK-eh
...Trick is prep work, and getting the surfaces clean! ...
That is why I like to grind down the entire outside of the block with a die grinder and an abrasive tootsie roll drum. It helps the paint adhere and keeping the engine clean is easier too. Looks nice too. You can grind off all the sharp edges and corners so manhandling the block is easier on your hands.
I know - call me "OCD".
Old 05-25-2015, 03:12 PM
fordman75's Avatar
fordman75
fordman75 is offline
I do the same thing! If you are going to make it look good, you might as well go all the way!
Old 05-27-2015, 09:09 PM
TheDudeAbides's Avatar
TheDudeAbides
TheDudeAbides is offline
indeed, go big or go home.
drewduncan15
03-21-2012 10:12 AM
sleep_deprived129
Paint & Bodywork
17
02-21-2008 05:51 PM
dynamis5
2004 - 2008 F150
03-25-2007 07:57 PM
instig8r63
09-30-2005 10:26 AM
Boss50
Paint & Bodywork
07-16-2005 01:45 AM
Quick Reply: Painting a 300I6.
