Electrical Feeds/Connections 12v Hot
Let me try asking in this section:
A newbie here, seeking assistance.
The truck in question is a 2002 F-250 Super Duty XLT w/V-10 Triton and ATw/OD.
I want to install an hour meter and running lights. To do so I need to locate in the engine bay a wire that provides 12v power ONLY WHEN IGN IS ON.
Can you tell me what color wire to look for, where it is located and what it is connected to?
I would also be interested in similar info as regards a wire that provides 12v power at all times, whether the ign is on or off.
I ask as my truck did not come with any docs of any kind, and repair manuals are on the way. I do not know what the repair manuals will have in terms of wiring diagrams?
Thanks!
Thanks!
On aircraft the engine hour meter (hobbs meter) normally is ground through an oil pressure switch, so it only run when the engine is running.
http://www.jamestowndistributors.com...owtos/834a.jpg
http://en.wikipedia.org/wiki/Hobbs_meter
Jim
Jim
Thanks for the advice and link. It never dawned on me to use the oil pressure switch for the ground. Makes sense.
The last truck I had the meter on the ground was on the firewall, and the power came from the wiper motor lead.
Incidentally, the meter I am installing is in fact a real, bona fide Hobbs meter. I was surprised the Wiki calls it a generic term. I do not know that the folks at Stewart-Warner would agree with that?
Jeep Guy
02-18-2006 06:14 PM
Billyboy501
Electrical Systems/Wiring
11-20-2002 05:15 PM
