Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Bank1 Sensor2 Where Is It?
Old 05-22-2015, 09:36 AM
a3mariner's Avatar
a3mariner
a3mariner is offline
Check engine light came on and stopped by the local autoparts store to get the error code.
Code: P2270
Bank1 Sensor2 fault
Where is this O2 sensor? I've replaced O2's on other cars I've had and just want to make sure I replace the right one.
Thanks!
Old 05-22-2015, 03:58 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Need more information
Is the vehicle in question equipped with a V6 or 4 cylinder? If 4 cylinder, it will be the sensor that is downstream of the catalyst. If V6, it will be the downstream sensor on the rear bank of cylinders (where cylinders 1, 2 and 3 are situated). As a matter of fact, another name for downstream 02 sensors is catalyst monitor sensors.
Old 05-23-2015, 10:24 AM
a3mariner's Avatar
a3mariner
it's 2.5 I 4x4
it's 2.5 I 4x4
You mean down the body past catalytic converter towards rear wheels?
Driver side? Passenger side?
Old 05-23-2015, 11:23 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Find the exhaust manifold where it comes out of the engine. There should be a sensor right there. That's the upstream sensor. Next comes the converter, there will be a sensor after it. That's sensor #2. There might be another converter, but since the information provided about your vehicle is insufficient, you will have to go out and look at it yourself.
Be aware that a fault code does NOT mean the sensor is bad, it means there is an issue with the signal or the circuit which may or may not be caused by the sensor.
Old 05-23-2015, 01:14 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
It could also be a fuel delivery or catalytic converter or some other problem and the sensor is merely doing its job....
Old 05-23-2015, 04:33 PM
a3mariner's Avatar
a3mariner
thanks all
Thanks again for the help. Replaced and fixed issue.
Just to note if you are little over weight or weight lifted then you might have to put up ramp to get to.fortunately dad's driveway is incline so moved to be able get under.
This is down on passenger side following the exhaust system about midway...but you won't see it unless looking from drivers side as plugs in from top into cat...
As others I've done on other vehicles these may be little tight to undo....this one was so rusted had to bang vise grips with hammer to start untwist.
Again love Amazon now even with overnight Sat shipping was still half price from auto parts store...
Also I always call Bosch to get right part number for sensor/vehicle as a lot times get quoted different part number from different auto stores or even sales clerks.
Teager
1999 to 2016 Super Duty
03-28-2024 11:44 PM
nut1605
06-08-2019 10:25 AM
ungerp
1983 - 2012 Ranger & B-Series
11-07-2012 08:39 AM
f142f142
1997 - 2003 F150
06-22-2011 09:05 PM
69deville
3.8 & 4.2L V6
01-16-2007 05:40 PM
Quick Reply: Bank1 Sensor2 Where Is It?
