1986 F 150 Ford Lariat
HI GUYS , I WOULD LIKE SOME ADVICE.
I AM NOT A MECHANIC AND NEITHER IS MY HUSBAND, BUT HE KEEPS SAYING HE IS GOING TO FIX MY TRUCK. """""nAAAA .
ANYWAY ABOUT 5 YEARS AGO MY TRUCK STARTED TO IDLE HIGH , VERY HIGH, THE LOCAL GARAGE COULD NOT FIND THE PROBLEM.
MY HUSBAND THINKS IT'S THE WIRING HARNESS???
THAT WAS 5 YEARS AGO AND I MISS MY TRUCK.
I WANT TO GET IT BACK ON THE ROAD, BUT IT'S BEEN SITTING IN MY GARAGE FOR THE LAST 5 YEARS.
HOW DO I GO ABOUT AT LEAST STARTING IT, WITHOUT RUINING MY GREAT ORIGINAL ENGINE.
THEN I WILL DEAL WITH THE HIGH IDLE PROBLEM.
My F150 Ford Lariat.
1986 F-150 Ford Lariat
I have not turned it over in 5 years because I have been told that I could ruin the engine, none of the oils have been changed, since it has sat. So I don't know how the trucks sounds. But it sure screeched high idle and would not stop . I had the same problem when it was about 5 years old, but a few fuel injector wires later it was fine. It has since had a whole new fuel injector . I just don't want my hubby trying to fix it and screwing it up. I already have to get the bar that runs between the two front tires replaced because he tried to haul his tractor out of the pond with it. That is why it's sittin in the garage. So when I can finally afford to fix it I will, so I figured maybe this year. I could have someone out to the farm and replace all the oils to start with. It's 4 wheel drive and it's got a 302. Not the greatest photo this was one winter a few years ago. I bought this truck on Jan the 3rd right off the transport. Never had a problem , always kept up with the maintenance and oil changes etc. Then I met hubby in 97, and being a man I figured he would care for it as I have. Nope. So it's not been driven .
So with your description it is a 302 Fuel Injected, that revs high when started, I'm not much a fuelie guy (Fuel Injected). What I would do is check the fluid levels, oil and water, you need both of these to be at proper level for the engine to run and not be damaged, if they look good enough, and the battery is properly charged, it can be cranked. First things first, look at the linkage to the throttle body (the part that moves when you pump the gas) and where it hooks up to the throttle body on the engine. If there is any binding or hanging anywhere this needs to be addressed, the high idle could be due to this catching on something (mechanical), after that I'm going to have to leave it to the others that are proficient with the Fuel Injected systems. Are you planning on doing this yourself? or get your husband to do it? regardless, posting images will be key in the board helping you getting the ole girl up and running again. Good luck
I think she's in Canada; there are five different chapters she can join/inquire in, I have no idea which one is closer to her:
Canadian National Chapter - Ford Truck Enthusiasts Forums
As for her truck's high idle, my thoughts are to get the engine running again and then pull the codes from the computer, begin there (as always with any computer-controlled vehicle).
F150 Ford Lariat
I read your reply and it's one I read to my husband, so yes, he will most likely do the work, but the linkage throttle body, that was a new one to him and I wrote it on my list of things to check. Thank you. I have not started yet , anything because as I said in my original post. What should I do?? And it's about money too. One step at a time.
I don't know if it was this post or another but someone mentioned turning it over , that can't be with these old oils that have been sitting in it for 5 years right. Shouldn't they all first be replaced.
For the next poster. I am in New Brunswick Canada
Emptying the old oil from the crankcase is never a bad idea; I would also first remove the spark plugs (be sure you label the wires so they can be reinstalled correctly) and pour some automatic transmission fluid into each cylinder to help with initial lubrication.
Make sure there is antifreeze in the cooling system.
And when Chris said to pour some automatic transmission fluid in each spark plug hole, he probably meant a small quantity [think 5 CCs; I am trying to think metric, since you are in Canada]. Actually, you could use more, but do not replace the spark plugs until you have allowed the engine to spin by using the starter motor. This will be messy, but will help lubricate the rings and cylinders. When the spark plugs are installed and the engine starts, you can expect plenty of smoke until the transmission fluid is burned.
The amount to use is one of those things where "it depends."
Ideally, one would thoroughly distribute it inside the cylinder bore so that it can seep down the entire surface of the walls and into the rings. But the only way I can think to do that through a spark plug hole would involve a syringe and a flexible silicon tube kinda like for an aquarium air pump (but more flexible, hence the silicon composition).
But that's probably unrealistic, so I would venture to say more is better here in a way to get it on as much of the wall surface as is possible.
If it's reasonable to get at the intake valves, then adding some there would be beneficial, too... this is easier to do with a carbureted engine, not so much with EFI.
tyrantsparky
02-07-2013 08:31 AM
91 Super Duty
08-24-2011 02:35 PM
