Saggy Backside
on
Big mistake to try to level up worn out springs.
Why well they just try to level your ground to bumper and say you want them a little beefier.
So they re-arch both spring packs then they had to add other spring or arch one spring a little more then the others to make up for the weak spring pack.. You will end up with two different looking springs packs when one is weak and worn out.
I would never have any springs re-arched again if one was weak.
This is when, I had a c/o camper on the truck. It's was kind of odd that both my passenger side springs were weak.
I first put in the front a pair of Add A Leafs that did some good but the right rear still sagged some. This was when, I later had them re-arched.
Yrs later found good front replacements and some HD rear spring at the JY
on a mid 70's pickup. It leveled my truck out and installed all poly bushings in them.
Orich
Been their done that!
Orich
Orich
dapozer
12-24-2005 07:36 PM
I_Thnk_Ford
02-28-2005 05:03 PM
