1955 f100 roof
Old 05-21-2015, 10:35 PM
jwelder's Avatar
jwelder
jwelder is offline
1955 f100 roof
Hi does any one know if some one makes a reproduction roof top for a 1955 f100 . the roof buy the drip edge is rusted out and needs repaired and I don't want to put the fiberglass one on from mid fifty
Any thoughts out there
Old 05-21-2015, 10:58 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Time for a new cab...should be many in AZ without roof rot.
Old 05-22-2015, 08:33 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Welcome to FTE!
From what I've seen here, that type of roof rot is fairly common and very problematic/hard to fix.
I agree that you should look for a different cab.
Old 05-22-2015, 11:44 AM
AXracer's Avatar
AXracer
AXracer is offline
Here's another vote for a replacement cab. AFAIK no one makes a replacement steel roof. It would be a very large difficult/expensive to warehouse/ship panel, as well as much more difficult to replace than it appears. A replacement cab would be far less expensive than the panel and labor, especially in the SW states.
Remember your truck is legally IDed/titled by the serial # stamped into the frame rail, so you can put any cab on your frame without any legal issues (assuming you have a good title on the frame you have). Any cab from 53-56 F100 - F650 will interchange with yours. The larger model truck cabs are often easier to find, and typically in better shape and less expensive, even if you have to buy the entire truck (selling off the big job parts, they are not reproduced, can often pay for the entire parts truck/make a profit.)
Old 05-22-2015, 12:27 PM
smallello's Avatar
smallello
smallello is offline
Try Johnny's F100 parts in Gilbert/Queen Creek area. They have lots of body parts, could be they have a roof. I'm sure they will have a cab.
https://www.facebook.com/therealjohnnysf100s
480-414-0100
Old 05-22-2015, 12:47 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
'56 is going to be different. I vote for another cab, as well.
Old 05-22-2015, 12:54 PM
AXracer's Avatar
AXracer
AXracer is offline
Yes, 56 cab is different but will still interchange with the 55 as long as you use the 56 doors and 56 hood hinges. All the rest of the sheetmetal forwards of the cab and behind it is the same or will interchange.
Old 05-22-2015, 02:12 PM
Jafo56's Avatar
Jafo56
Jafo56 is offline
Ok I vote for another cab as well! Very difficult to fix!
kys911t
01-24-2017 07:41 PM
matterick
10-22-2014 07:34 PM
dozer72
04-22-2011 10:54 PM
rods4life
10-10-2008 07:56 AM
nomadshirt
10-25-2004 07:34 AM
Quick Reply: 1955 f100 roof
