My ford 2006 f350 king ranch problem need some advice
So I have a ford 2006 f350 Turbo diesel King ranch if anyone could help me trouble shoot this and I hope it isn't to painful since I only had the truck for a week and half now.
So I was driving down the free way and I went to pass someone and I pressed down on the gas to floor it and I got going fast and I heard the boost and looked behind me and see black smoke blow out my stack.
I got off my exit but it seems I have no power it doesn't get up and go like the beast it is.
It feels like the pedal wont give it the power it needs or something.
I did notice the boost isn't working now either.
Gosh im new to trucks and stuff but im guessing this isn't a easy fix?
If anyone has any suggestions please let me know
Ill smile now before the out come
I can drive it it goes slow until it gets up to speed but does blow some smoke now.
Safe to drive for now? If there is anything I can look for now??
Last edited by AxeDigger; 05-21-2015 at 08:43 PM. Reason: Had to add something else
Yea it was the weirdest thing ever just like something had quit.
Im not much into motors if it were a motorcycle that would be something else but ill take a peak at things.
I wish it was something that just come off
Well the Truck is to hot to be touching anything im not driving it tomorrow so ill check when I get home. Its very odd to be that this would happen.
The Turbo wouldn't just blow up and be toast like that would it?
Its weird like something come off or not connected at least im hoping for that
I guess I could google that google has been my friend you folks are great on this forum since I joined.
As far as the scan gauges yes I will for sure get that someone was guiding me to that on another thread I hope this is a easy find and fix and yes I will for sure be getting them scan gauges . Not to get off topic but do those pretty much just tell you when something is about to happen or point you to the problem?
Ok lets try to make this easy. Open your hood, look the the turbo kinda looks like a giant snail. From the turbo you will a rubber tube usually blue if stock can be other colors That connects to a metal tubing about 3" around. That runs to the front of the truck to the intercooler there will be another rubber boot connecting the tube to the intercooler. Check those really well the one right by the turbo is usually first to Pop. The ckld side if stock has a plasic tube that can crack as well.
Look at the large BLUE tubes (the one with the yellow sticker on it, not the small blue hoses) in post #3 here and then the diagram in post #1.
https://www.ford-trucks.com/forums/1...duct-blew.html
On yours, the left hand tube should be silver with blue (likely oil soaked and now black) boots, and the right hand tube should be black plastic. What happens is the boots degrade after oil from the crankcase vent soaks them, and eventually they fail. If they pop off you usually hear a big bang and have no power, but they can also tear which is a less spectacular failure but gets the same result of no boost. You might have to entirely remove the tube to check each boot all the way around to make sure there are no tears in the left side one, and no cracks in the plastic right side one.
These are the most popular replacements for the CAC boots and hose clamps if yours are soaked down:
Ford - 03-07 Super Duty 6.0L - Turbo & Related - Intercooler CAC Boots - Riffraff Diesel Performance
That site is a sponsor here, and he makes great 6.0 and 7.3 parts.
Look at the large BLUE tubes (not the small blue hoses) in post #3 here and then the diagram in post #1.
The tubes are for compressed air, so there shouldn't be any liquids in them, defiantly nothing that you should have to "drain" for. There's always some oil in the CAC tubes, it comes from the crankcase vent that's in the intake tube between the air filter and turbo inlet. There shouldn't be more than a few teaspoons of oil between both CAC tubes, if there is then either your crankcase is overfilled with oil (more likely), or the turbo is having problems (rare on the compressor side).
Since you're newer to the 6.0, here's a some information just about the engine in general. You can come hang out with us in the 6.0L Engine Forum, that's where the really detailed information tends to be discussed
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
6.0L Tech folder:
https://www.ford-trucks.com/forums/3...ch-folder.html
This is where we keep "common" things like filter changes, basic repairs, and popular modification.
One example of what's in there in this checklist of items to cover when someone buy's a a 6.0 and needs kind of a "quick-start" guide on what to search for in the forum:
Recomendations for New to me owner of a used truck:
Ford Truck Enthusiasts Forums - View Single Post - Just bought 06 F350 FX4 6.0!!
You can also put your email into this thread and someone will email you a whole bunch of information that's too large/detailed to be posted into the forums:
https://www.ford-trucks.com/forums/7...ew-owners.html
Even the basics of what brand of filters to buy and what kind of oil play a big difference in how the engine holds up. The electrical system is critically important since Ford installed an undersized alternator, so really read up on batteries and alternator upgrades, that's the easiest thing to prevent engine problems from cascading.
6.0L Tech folder:
