50 F3, flathead, Toyota box, need headers
I just finished installing a Toyota box on my 50 F3 with a flathead v8.The left exhaust manifold touches the Toyota box. I was going to use headers since I wanted dual exhaust. I also want to keep the clutch and use the stock steering wheel.
I was planning on using Speedway's center dump headers. They appear to be similar in size to Sanderson. The Sanderson headers might "hug" the engine closer. I have read that a lot of people use Red Headers.
So has any one installed any of these headers and could recommend a solution that would fit?
I can't help with the header question, but go into user cp in the blue band at the top of page and turn on receive PMs. I live in Durham and want to see if you'd like to get together and kick tires sometime. If you don't want to receive PMs, then PM (left click my user name and select send PM) or email me your email addy if interested.
The Toy box is less than 1/8 of an inch from the frame. I can move it if I cut the frame 1/2 inch and then trim 1/2 inch off the mounting bracket. I worry about the steering column aligning with the Toy box if I do that. I also wonder what happens to the drag link if the pitman arm moves over 1/2 inch.
Can you tell me how much clearance you have with Red Headers? I guess what I need is how the headers drop as they go from the front of the engine to the rear. As you can see in the picture the stock manifold bottom edge hits the corner of the box. For the Red Header to clear the rear exhaust port would be to be around 5 inches from the bottom bolt that holds the header to the engine. See my attempt at drawing.
