Today's 9" progress
Today's 9" progress
I finally got smart and bought a bench mounted third member rotisserie. What a nice thing to have for us old guys. OK update, Brakes done, axle housing done, axles done and third member is all cleaned and ready for reassembly. The only thing Im waiting for is a "Depth Micrometer" that is scheduled for delivery on the 27th (the last piece of the puzzle). Then Ill be able to take the pinion depth and axle centerline readings I need to set my depth up accurately. Well that's it for today. Not much of a thread, I know, but I just felt like checking in and sharing. Ill do an album or build thread after I get done with this thing.
Jim, I am signing up for your thread. I am driving my 49 with a 9 inch rear, same as yours. The rear is one of the few parts of the truck that I did not do personally. I had a friend of a good friend rebuild it, I supplied all of the parts including the trac lock setup. I bought the rear as an open rear and bought the trac lock separately. I had him rebuild it using the original 3.70 gear set. Now for the news: I have developed a whine when on the throttle even slightly (not off the throttle). My internet research indicates this is not all that unusual. One potential issue that I see is using the original gears there are those that claim that the gears wear in and if the pattern changes it can cause the whine. I would be interested in your experience and what others on the forum offer. Not to hi jack yourthread since I think that you also want to avoid the whine, so have at it!
I've been debating replacing the whole 3rd member of my 9" Ford vs replacing a pinion seal. The seal started leaking after the truck sat in the garage for two years (other priorities).
Since I know squat about rear ends (mechanical), I'd like your opinion Jim.
Would the seal be easy to replace? Thanks.
There is a group of video mechanics on U-TUBE that go by the name of "CAR TAPES" who have an excellent four pat series on tearing down, inspecting and rebuilding the ford 9"
that I have found very helpful. Im pretty much at a stand still until I get my depth mic. So until then have a great day.
