Today's 9" progress
Old 05-21-2015, 01:31 AM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Today's 9" progress
I finally got smart and bought a bench mounted third member rotisserie. What a nice thing to have for us old guys. OK update, Brakes done, axle housing done, axles done and third member is all cleaned and ready for reassembly. The only thing Im waiting for is a "Depth Micrometer" that is scheduled for delivery on the 27th (the last piece of the puzzle). Then Ill be able to take the pinion depth and axle centerline readings I need to set my depth up accurately. Well that's it for today. Not much of a thread, I know, but I just felt like checking in and sharing. Ill do an album or build thread after I get done with this thing.
Old 05-21-2015, 02:12 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
whats it cost? looks easy to make.
Old 05-21-2015, 02:45 AM
underthebridgejim
FTE fan
It was 39.99 at Speedway. Its positioning is adjustable ,tension from loose, to a hard lock in any position. I was very pleased with the quality.
Old 05-21-2015, 06:38 AM
JimG1098's Avatar
JimG1098
JimG1098 is offline
You are making great progress of the "unknown"
Old 05-21-2015, 07:10 AM
TonyB55's Avatar
TonyB55
TonyB55 is offline
For $40, that looks like a handy gadget. I can't crawl around on the floor, working on this stuff anymore. It looks like you're doing a careful job on that, Jim.
Old 05-21-2015, 09:15 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Nice work Jimmy.
Say, what's that calendar with the manure spreader on it?
Old 05-21-2015, 12:39 PM
49willard's Avatar
49willard
49willard is offline
Jim, I am signing up for your thread. I am driving my 49 with a 9 inch rear, same as yours. The rear is one of the few parts of the truck that I did not do personally. I had a friend of a good friend rebuild it, I supplied all of the parts including the trac lock setup. I bought the rear as an open rear and bought the trac lock separately. I had him rebuild it using the original 3.70 gear set. Now for the news: I have developed a whine when on the throttle even slightly (not off the throttle). My internet research indicates this is not all that unusual. One potential issue that I see is using the original gears there are those that claim that the gears wear in and if the pattern changes it can cause the whine. I would be interested in your experience and what others on the forum offer. Not to hi jack yourthread since I think that you also want to avoid the whine, so have at it!
Old 05-21-2015, 03:57 PM
edzakory's Avatar
edzakory
edzakory is offline
I've been debating replacing the whole 3rd member of my 9" Ford vs replacing a pinion seal. The seal started leaking after the truck sat in the garage for two years (other priorities).
Since I know squat about rear ends (mechanical), I'd like your opinion Jim.
Would the seal be easy to replace? Thanks.
Old 05-21-2015, 04:08 PM
underthebridgejim
FTE fan
There is a group of video mechanics on U-TUBE that go by the name of "CAR TAPES" who have an excellent four pat series on tearing down, inspecting and rebuilding the ford 9"
that I have found very helpful. Im pretty much at a stand still until I get my depth mic. So until then have a great day.
Old 05-21-2015, 04:36 PM
underthebridgejim
FTE fan
Originally Posted by Jolly Roger Joe
Nice work Jimmy.
Hi Joe, The calendar was a freebie from Dennis Carpenter. In came in one of there box's.
Old 05-21-2015, 04:46 PM
topmoo's Avatar
topmoo
topmoo is offline
They only put the best looking trucks on their calendars
underthebridgejim
FTE fan
This is my first rear end, but from my understanding the pinion depth and preload is done with the seal out and its(along with the oil slinger) put in after the mentioned settings. So replacing the seal should not affect your settings as long as the pinion nut was and will be set to the correct torque. But like I said I'm not an expert by any stretch of the imagination.
Old 05-21-2015, 08:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Strictly speaking, you are supposed to replace the crush sleeve if you loosen the pnion nut (like to replace the seal). Most people don't, I'd wager. You may need to replace the yoke to get a leak-free setup tho. Most of them I've seen on older axles have a pretty bad groove in them.
Old 05-21-2015, 10:02 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is online now
Like Jim said, replacing the pinion seal is an easy fix as long as you hand torque the pinion nut back on (no impact gun)and don't forget to add sealer to the pinion splines, that is wear a lot of the leaks come from.
Old 05-21-2015, 11:27 PM
underthebridgejim
FTE fan
Dave and Ross are both professionals, so definitely follow whatever they say over anything I may advise. I'm a student they are the teachers. PS thanks guys for chiming in.
Quick Reply: Today's 9" progress
