LED Halo Headlights
on
You want some advice, put them back in the box and return them.
Those lights have a horrible reputation, they leak, light output is horrible, LED's burn out, Halo's go out and just don't fit well for most.
If you plan on keeping them though, did they come with instructions? If they don't come with a wiring diagram, that is another thing to add to the list. If no instructions, use a 9v battery to see what lights up (a 9v has enough juice to light up LED's without messing anything up if you hook it up backwards). Black should be ground, red will be positive, blue, well, could be either.
I have to agree. The only thing more frustrating than wiring those will be how short of a time they work. Your going to spend more time installing them then getting to use them. That Chinese garbage isn't worth the box they come in which is a shame because they look pretty good.
Sorry to say this is one of those areas you get what you pay for and a $100 set of headlights is like flushing a $100 note right down the toilet.
Kremerica
6.7L Power Stroke Diesel
06-29-2019 08:08 PM
Wes444
10-03-2017 06:36 AM
