Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Removing drip rail putty
Old 05-20-2015, 02:57 PM
Dannym Dannym is offline
Dannym is starting off with a positive reputation.
I have an '83 van (not many people on van forum, the problem should be the same anyhow) with a leaking drip rail.
Many years ago, before I got it, someone applied a putty to fill the drip rail in. I don't know what it is, but it shrunk a LOT and pulled away from the steel on both sides and actually makes it collect MORE water.
It's heavily cracking, still somewhat rubbery, and about 1/5th of its surface actually is still stuck to the metal. I tried prying with flatblade screwdrivers and only got a few inches to break off. Tried grabbing an end and pulling while prying a screwdriver back and forth to try to get it off but it just tore off from the attached portion.
I've got a lot to remove. Any ideas? I did have some ideas about just pouring in more sealant around it, which is surely a bad idea, but I don't know if there's any practical way to ever remove this crap.
Old 05-20-2015, 03:34 PM
SSellers SSellers is offline
SSellers is gaining momentum as a positive member of FTE.SSellers is gaining momentum as a positive member of FTE.
Maybe something like this?
Avanti Pro 4 in. Drill Mount Quick-Strip Wire Brush-PWW040WIRD01G - The Home Depot
As far as sealing it back, here's what I did:
Did not try to remove the old cracked seam sealer, and it didn't have any "previous owner mods".
Wiped it down with 99% isopropyl alcohol.
Rolled up a piece of sandpaper to run in it and scuff lightly.
Wiped down again.
Used E6000 automotive sealant without a nozzle (available at the parts store) and filled in the length of the drip rail. E6000 is a self-leveling non-hardening non-shrinking sealant. Thought about using seam sealer but the truck was white, I only had a day to do it, and the stores only had gray in stock.
Old 05-20-2015, 04:30 PM
I have the wire wheel, planned to use it for rust removal. I don't expect it to be effective at taking off this thick, hard rubber. It's like 20 ft+ total, too.
If I can't take the old sealer off, I don't know where that leaves me. I can't remove the rust in the gaps around the old sealer and I don't expect even E6000 to get a good bond there. Even if the E6000 sticks to the rust, the rust will flake off the steel and make a new gap.
E6000 has UV-grades and not. Unless it SAYS "UV", it's not! It'll rot in the sun in a few months outside.
Also "Amazing Goop" is the same company as E6000. Same polymer, too, just a different solvent. They divided out into many products under many names for marketing purposes. But they're not very different.
The "RV Goop", "Outdoor Goop", "Shoe Goo" are all the same polymer with UV inhibitors.
Old 05-20-2015, 05:24 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud of
Can you get under the end and use a chisel to pry it out? Once it is out, assuming it is out, use the wire brush to clean it up. But, you won't get all of the rust, so then use something like POR-15 that will adhere to and kill the rust. Then cover that with a seam sealer that is UV stable.
__________________
Rusty: '81 F150 Ranger XLT 4x4 w/a 351M, RV cam, Performer carb & intake, C6, & 3.50's
Dad's: '81 F150 Ranger XLT 4x4: Down for restomod: Full-roller "stroked 351M" w/Trick Flow heads, Weiand intake, Street Demon 750/ZF5/3.50 gears w/Kevlar clutches
1950 Chevy 3100 & 1969 Super Bee awaiting restoration
Big Blue: 2015 F150 Platinum 4x4 SuperCrew wearing Blue Jeans & sporting a 3.5L EB & Max Tow
Worst fear: I die and my wife sells my rides for what I've told her I have in them.
Old 05-20-2015, 05:37 PM
I'll have a chisel to try soon. But I don't think it'll work. The steel isn't super-thick and I don't want to drive it through the steel.
I imagined prying it up, but the drip rail isn't that sturdy. And I had another look- most of the separation is on the roof side, not the drip rail's lip side. Nothing to take leverage against for prying.
I was hoping to use a truck bedliner spray. That's sturdy stuff, adheres very well to metal, and very weatherproof. I'll tape it against overspray but this is hardly a "nice" vehicle to begin with.
Old 05-20-2015, 05:46 PM
Gary Lewis's Avatar
If you have rust and don't get it neutralized it'll just keep eating the metal.
__________________
Old 05-20-2015, 05:58 PM
Quote:
A lot of people say that, but it's not quite the case. Rust isn't contagious, except obviously a piece shedding scales of rust has no paint or even oil underneath it. And it traps moisture for longer than if the rusted metal were brushed off.
But additionally if you don't clean the loose rust and just paint over it, the rust scale will shed and take the paint layer with it, defeating the paint and exposing it to water all over again.
The bedliner spray is supposed to be unusually tolerant for applying over light rust without a primer. But not loose rust scale, of course. Regardless, I plan to wire brush it. If there's any notable holes I think I'll try to bridge them with fiberglass cloth first, then apply the bedliner spray.
A lot of people believe "rust converter"/neutralizer (naval jelly, phosphoric acid) seals off rust. These products do convert the rust, except: one, any loose scale must still be removed first, and two, the surface must be painted or at least primed. It doesn't create an effective barrier to new rust. So it essentially means you don't have to brush it as thoroughly and yields a better surface to paint on, but it must still be painted.
Old Yesterday, 01:29 AM
Hmm getting pretty good resulting using a wood chisel to pry it off from the gap where it pulled away from the roof.
Old Yesterday, 03:50 PM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a very good reputation on FTE.FordFETruck has a very good reputation on FTE.FordFETruck has a very good reputation on FTE.FordFETruck has a very good reputation on FTE.
Bout2GetWhooped
I used a 90 degree seal pick to remove the seam sealer from the drip rails on my pickup. Although mine was so hard it all came out and shattered. That made it easy.
__________________
-Matthew
1986 Ford F-250 XL 4X2 351W H.O. Weiand Stealth Intake, Comp XE250H Cam, Comp Magnum Rockers. Summit/Holley 600 CFM 4010 4V Carburetor. 130A 3G Alternator. PMGR Starter. 10.25" Rear With Open 3.55:1. 233,000 miles.
Old Yesterday, 08:06 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I would try a heat gun. The type that you get at Lowe's to remove paint. It may soften it enough so it gives up easier.
__________________
Dave F
1989 F250 XLT Diesel
Old Yesterday, 08:47 PM
reamer's Avatar
reamer reamer is offline
reamer is gaining momentum as a positive member of FTE.
this is how the cab corners rust out, Crack in the gutter, water rolls down the inside where you cant see it and rust starts on the floor and corner
__________________
1984 F-150 4x4 XL, Flareside 351, NP 435, soon to have a ZF 5-sp and Boss Hoss decals.
Old Today, 07:22 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Rust is Contagious. That is why they call it cancer.
There is one ONE way to kill rust. And that is remove it
A. sandblast the metal clean(until no rust is left)
or
B. Cut all the rust out
__________________
Looking for Blue 40-20-40 seats. PM me !!!
Old Today, 07:22 AM
Similar Threads
Fuel Rail Won't Re-Install - 98 Expedition 5.4 - Need Help!L Shorebreak Expedition & Navigator 10 05-14-2015 06:52 PM
Aligning the pump gear. akamacgyver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 07-10-2014 02:51 PM
Drip Rail Question/Resto Project Supercab_Max 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-16-2013 02:11 PM
DIY Painted Headlights - aka a $10 Harley Mod Tylus Super Duty & Heavy Duty 70 06-21-2013 05:50 AM
Power Lock Fix instructions with pictures! Tom Excursion - King of SUVs 19 05-14-2013 09:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
