1984 f250 6.9 intermittent right rear brake / signal light failure
the gremlin in my 84 f250 is causing me to hit this forum again.
the r. rear signal, brake, hazard light works, and then, doesn't work.
I have replaced the brake switch ( wires were messed up some)
replaced the bulb( with the correct bulb)
cleaned the contacts in the socket.
traced, checked and cleaned any splices on wires.
tested with test light both sides of multi connector under rear frame.
examined the 10 wires on steering column, wrote down color code and what it goes to.
this is a non tilt, manual, 4x4, diesel. all the other lights and indicators work fine.
right side running lights fine.
this has been going on off and on for a while.
I am replacing r. rear socket on general principles.
maybe need to do something with the turn signal switch?
it seems stiff, dirty. can I just clean it, or better to replace it? ( yeh...pull steering wheel, ok)
anybody else had this kind of problem, solution?
Yes I had this problem. it is most likely behind your steering wheel. I bought a puller for $10 at a local auto parts store. its super easy and self explanatory once you get started. you may find bare exposed wire where the insulation has rubbed off by the steering wheel. this will short out the lights. wrap with tape and good to go. or check your turn signal switch , it may be bad.
it has been raining here, and we just saw water dripping from the top of the windshield right into the steering wheel and column... you think?
so...o'reillys rents pullers and rock auto has the switch. fast glass the windshield. ( gaskets are no doubt dried out and cracking) bandaid a bit of silicone up there until the windshield can be dealt with.
thanks, etone, for your ideas.:
Michael McQueen
02-26-2012 12:14 PM
T. Pecanic
08-07-2011 08:24 PM
