Lining up a new core support?
Hey guys, I'm replacing the core support in my Ranger. I have the new one sitting in the truck, held in with vise grips. I have it eyeballed pretty good but I'm having trouble with measuring to square it up.
I read somewhere that to line up the core support you were supposed to measure diagonally from the farthest back bold hole on the fender, to a front bolt hole on the core support.
Problem is that on the Ranger, A) there are no bolt holes on the top of the core support, and B) the rearmost bolt holes on the fenders are not the same distance from the firewall.
I can use the corner of the hood bumper openings for a measurement on the core support, but I don't know where to measure to on the truck's body. Complicating the situation is the fact that nothing I can measure to is above the engine, meaning I have to run the tape across the engine and everything stick up off it which I know is throwing off my measurement.
Also, how can I make sure it's also square up & down?
You are very correct on the diagonal measurement for ensuring straightness......I have no experience with the Ranger's but, you can also use a string and extend that even to the outside of the engine compartment to other components that you can verify are "straight". When all else fails, a level, square based off of known good points sometimes just has to do.
I did find out the rear fender bolt holes are the same distance from the firewall, it just doesn't look like they are...it's weird.
I've gotten it to where it's within 1/16-1/8" diagonal but can't seem to get it any better than that. It seems the top of my el-cheapo ebay core support was actually attached about 1/8" off center so maybe that's where my error is coming in.
In a perfect word everything would fit perfectly the first time--sadly body work just ain't perfect.
As a former body shop owner I can tell you even factory parts can be slightly off, giving even the pro's fitting issues. Measuring is the best first step, final fit and operation of doors, hoods ect determines what needs adjusted or repositioned.
In the end I kinda did. Got the diagonals close on top, "eyeballed" the bottom and then made sure both sides were the same distance from the front crossmember and welded it it.
I put the fenders back on last night and then test fit the front fascia, and so far everything looks pretty good!
hello113
07-19-2017 03:41 PM
68cabby
04-14-2012 12:54 PM
BossEliminator
11-04-2004 12:16 PM
