pyrometer broken, or wiring issue? - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Log In
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-19-2015, 09:20 PM
Ezalycasaid Ezalycasaid is offline
Ezalycasaid is starting off with a positive reputation.
I just installed a glowshift 3 pod, Pyro, Boost, Tranny guages. On a 96 7.3 PSD. My pyrometer doesnt seem to be working though. Everytime I turn it on its a different color and it goes from 0 to 1500 then back, then to 1500 and stays there. Any suggestions?
Old 05-19-2015, 10:05 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
The color light selector is the only **** on there. The first part of the movement of the guage is test movement. Staying on 1500° 'might' be a bad ground, guessing on that.
__________________
Glenn
The Mule-96 2WD F250 EC/LB auto PSD, semi-retired.
The old gray Mare 97 dually cc, rest in peace.
The Blue Ox 97 dually EC, all stock.
Old 05-19-2015, 10:18 PM
fordpride's Avatar
fordpride fordpride is offline
Louisiana Chapter LDR
fordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud of
You should have a memory with that gets 12v constantly.
Far as staying on 1500* it could be a bad connection, bad probe, bad gauge.
Hopefully you didn't cut the wires to the probe to shorten it. That will mess up the reading
__________________
Mike
Click here to join the Louisiana chapter
2014 RAM 3500 cummins
96 F350 CC ZF5 53k with grandpas package
Louisiana FTE Member Map
Old 05-19-2015, 10:35 PM
Quote:
I did cut the wires but right at the crimps where they connect to the other wires on the gauge. So I basicly cut out 1/4" of wire and put on new crimps. Could a 1/4" make a difference?
Old 05-19-2015, 11:00 PM
fordpride's Avatar
Cutting the wires changed the resistance of the probe
__________________
Mike
Old 05-20-2015, 09:58 AM
So if cutting a quarter of an inch changes it that much then, what happens if on the gauge side you add a connector thats a 1/4" longer then the other connector? Does that completely throw off your reading as well? Because the kit didnt include a connector for the gauge side.
Old 05-20-2015, 04:22 PM
Traced all my lines back to the gauges and the probe. Had a bad connection, one of the new connections I put on slipped down. Put it back together, ran the truck and checked the manifold with a temp gun to make sure the gauge was reading correctly. Everything's working great and the gauge comes on green every time. Lol just a bad connection. Thanks for the help guys.
Similar Threads
Pyrometer Install Schmitty133 6.0L Power Stroke Diesel 51 02-05-2015 07:58 PM
turning up injector pump natedowney Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 09-29-2014 11:36 PM
Which of these 2 Pyrometers 1986 F250 6.9 IDI automatic 2wd jakegaisser Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 06-03-2014 01:01 AM
Installing a pyrometer big ole ford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 03-07-2014 09:01 PM
Do I need a pyrometer? 7.3idi1992 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 08-06-2013 10:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
