1999 F250SD Vacuum lines? - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign In
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Old 05-19-2015, 08:20 PM
rangerbud rangerbud is offline
rangerbud is starting off with a positive reputation.
Does anyone know where to find the vacuum(I assume it is a vacuum line) that controls the direction of air flow to either vent-floor-or defrost? I bought the truck new in 99 and expect I probable have a cracked vacuum line. Or maybe there is another control device that changes where the air goes to.
Appreciate any help
bud
Old 05-19-2015, 08:42 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
Common problem on fords, most of the time it's a leak on the 4x4 system that uses the vacuum system.
iPhone from IB AutoGroup
__________________
2004 F-350, XLT, SC, SB, FX4, 5.4, 4R100 w/ .472 line mod valve & TransGo HD2 reprogramming kit, 4.30 gears w/ Detroit locker, zoo dad mod w/ STOCK intake, Gibson stainless headers, SPD y-pipe, 51509 cat, Borla 3" exhaust, 1" rear AAL, dually upper and lower overload spring, 08 diff cover, ProComp 22210 springs, more.....
Old 05-20-2015, 09:06 AM
kb3mtv kb3mtv is offline
kb3mtv is starting off with a positive reputation.
I had a problem with mine when I bought it, the previous owner replaced the auto hubs with warn manual hubs and cut the vacuum lines and just left em.
The line that controls the plenum should be coming out of the firewall on the passenger side right by the blower motor. Its a black line if im not mistaken
Similar Threads
Climate Control Vacuum Lines jfmaz 1987 - 1996 F150 & Larger F-Series Trucks 12 05-22-2014 12:01 PM
vacuum line into cab for heat. tjc transport Super Duty & Heavy Duty 5 10-23-2013 12:14 PM
Climate control vacuum diagram choptop49ford 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-15-2013 09:08 PM
Climate control Bombdog1 1987 - 1996 F150 & Larger F-Series Trucks 3 07-30-2013 10:40 PM
Missing Vacuum Hose -help AQUARIES1 1978 - 1996 Big Bronco 27 01-08-2004 08:35 AM
Tags
1999, diesel, f250, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
