92 7.3 Quits At 3000 Rpm
What kind of shape in the IP in? There is a governor inside the IP that might have somehow gotten turned down for some reason. Since there is no ignition to speak of, the only limitations you have are air and fuel. Unless there's something in the way of the air coming in, that would only leave the fuel. If your fuel pump is fine, that would leave the IP. Either it wasted, or the gov. is set too low. If it's a recent rebuild, that would most likely be the case.
__________________
02 Ranger 4.0, 5-speed, 4x4 FX4
72 Bronco, 351W, C6, 4.10's, tube buggy
79 Ford with 93 Chevy body, 460, C6
